Forum Home Forum Home > General Camping > Cook'n With Gas
  New Posts New Posts RSS Feed: Dutch Oven - Cleaning
Topic ClosedDutch Oven - Cleaning
rpodcamper.com View Drop Down
Direct Link To This Post Topic: Dutch Oven - Cleaning
    Posted: 08 Dec 2009 at 12:27am
Dutch oven care starts with the seasoning of the metal, but the second step is to make sure you clean your ovens properly after each use. More often than not, cleaning cast iron Dutch ovens is much easier than scrubbing pots and pans. For cast iron, the cleaning process is in two steps. First, food is removed and second, maintenance of the protective coating. To remove stuck on food, place some warm clean water into the oven and heat until almost boiling. Using a plastic mesh scrubber or coarse sponge and No Soap, gently break loose the food and wipe away. After all traces have been removed, rinse with clean warm water. Soap is not recommended because it will break down the protective covering and will get into the pores of the metal to taint the flavor of your next meal.
After cleaning and rinsing, allow the oven to air dry. Then heat it over the fire just until it is hot to the touch. Apply a thin coating of oil to both the inside and outside of the oven and the top and underside of the lid. Allow the oven to cool completely. If you do not oil the outside of the oven, then with use, the protective barrier will break down and the oven will start to rust. As a suggestion, it is a good idea to keep a scrubber for cast iron and never use it with soap.
For aluminum ovens, the cleaning is the same as for ordinary pots and pans. Use soap and water and scrub them as you would your other pans.
