  New Posts New Posts RSS Feed: LEAKING HOSE  OUTDOOR SHOWER
Topic ClosedLEAKING HOSE OUTDOOR SHOWER
scott59 View Drop Down
Direct Link To This Post Topic: LEAKING HOSE OUTDOOR SHOWER
    Posted: 24 Apr 2017 at 12:31pm
I have a leak in both hoses that connect to the outdoor shower (brand new 2017 178 R-pod). There doesn’t seem to be a leak at the other end of the hose where they connect to the sink. I have hand-tightened as much as possible. I don’t want to break the plastic connectors. I did get a new hose at Home Depot but the problem persists.
However, when the water is turned on, pressure in the lines builds up and the leaks start. Am I missing something in the installation process? Will plumber’s tape help fix the problem?
We are scheduled to have Camping World look at it on 5/3 the earliest we could get in. We have a trip planned leaving 5/5. So we are trying to fix the problem on our own.
Subzilla View Drop Down
Direct Link To This Post Posted: 24 Apr 2017 at 1:58pm
Unscrew it, look in and make sure the rubber washer is in the hose connection.  Or make sure it's not damaged.  The new hose should have included new rubber washers.  Look closely at the male connection at the faucet to make sure it's not damaged.
Mark
Concord, NC
2017 RP 179 "Podzilla"
2011 Silverado 1500 4X4
Direct Link To This Post Posted: 24 Apr 2017 at 3:51pm
If your 178 is like my 179, then the lines connecting to the outside shower were just brought up and bent to attach to the shower. I saw that mine were leaking and one of them was somewhat kinked. I did not like that, so I bought two elbows. I used some Teflon tape and attached the elbows to the shower connections. Then I attached the supply lines to the elbows. Now they run straight up to the connection with no bend. You may wish to do something similar depending on the setup in your 178.
Direct Link To This Post Posted: 25 Apr 2017 at 7:30am
Didn't pay attention and realize you were talking about the supply lines...thought you were talking about the faucet-to-showerhead line...my bad. I would have suggested the Teflon tape or liquid Teflon to fix.
Mark
Concord, NC
