  New Posts New Posts RSS Feed: Dometic serial number
Topic ClosedDometic serial number
Wepod View Drop Down
Direct Link To This Post Topic: Dometic serial number
    Posted: 07 May 2017 at 6:03am
Hi. I am trying to get the serial numbers off my frige and air conditioner on my 2017 179 where are they located?
Richand Cindy View Drop Down
Direct Link To This Post Posted: 07 May 2017 at 8:05am
In your packet of materials you should have received a yellow sheet of paper with all of the model numbers and serial numbers of the items in the POD.  However when we went to register the refrigerator the serial number was not accepted.  We looked inside the refrigerator and there were no stickers with registration numbers.  We then went outside and removed the bottom black plastic panel for the refrigerator and the serial number was there (and was different by four digits) and worked when I went to register online.  Do not know where the a/c serial number is.
Craneman View Drop Down
Direct Link To This Post Posted: 07 May 2017 at 9:30am
On our fridg it inside on the back wall, if I remember right you have to take the drawer out
Jo and Gary
2010 174
2011 Ford 150
Direct Link To This Post Posted: 07 May 2017 at 4:03pm
You are correct Gary.  By removing the bottom drawer, the serial number is located on the back wall.
Direct Link To This Post Posted: 07 May 2017 at 4:23pm
As a side note.. the factory warranty started the day you signed on the dotted line, any questions anyone has been asked about warranty work revolved around that.
Direct Link To This Post Posted: 07 May 2017 at 7:47pm
Richand Cindy   I had the same problem when I tried to register the fridge's number with Dometric only I was sent a letter which stated that the sticker was on the wall by the door.   They also rejected the air conditioner number and stated that the number could be seen by looking in the return grill of the unit.  Try looking up through all those little holes some time and trying to see something in there almost impossible  Any way I did find the number for the fridge thanks to all for the help.  But I still need the AC number.
Direct Link To This Post Posted: 09 May 2017 at 6:47am
I can still use help finding the AC serial number sticker let me know.
