2018 changes
Forum Name: Reviews and General Information
Forum Discription: Find r-pod reviews and new product announcements here
URL: http://www.rpod-owners.com/forum_posts.asp?TID=10718
Printed Date: 08 May 2024 at 2:51pm Software Version: Web Wiz Forums 9.64 - http://www.webwizforums.com
Topic: 2018 changes
Posted By: Subzilla
Subject: 2018 changes
Date Posted: 27 Sep 2017 at 12:43pm
Just looking a Couch's RV Nation website to see what changed in the 2018 models. The only things I could visibly see were the aluminum DOUBLE steps and the change to the Furrion bluetooth stereo with a separately mounted speaker switch on the RPOD wall.
No issues....just observing. I did just buy a set of double steps as our single step is more like a jump.
------------- Mark
Concord, NC
2017 RP 179 "Podzilla"
2011 Silverado 1500 4X4
Posted By: jato
Date Posted: 27 Sep 2017 at 8:04pm
When we purchased our 177 back in January 2011 one of the first mods I did was to re-do the steps as the first step out the door was 11 inches and the second to the ground was 5," By taking it off and re-configuring the way it attached to the bracket I was able to make it 8" on both steps, much easier for entering and exiting. And yes, we never did get the 4" adapter to make the pod sit higher. If I ever do that then I will do as you did and purchase a double step setup.
------------- God's pod
Posted By: Mcjclarks01
Date Posted: 28 Sep 2017 at 8:19pm
Unfortunately FR is going with new fabric. For our model we had to pick one from the new selection due to it still being built. This is what our dealer sent us from three models they have on their lot with the new fabric color choices:
Slate-
http://www.hrvc.com/rv/wilmington+nc/forestriver+traveltrailer/1303/forest+river+r-pod+179
Stone-
http://www.hrvc.com/rv/wilmington+nc/forestriver+traveltrailer/1306/forest+river+r-pod+179
Desert-
http://www.hrvc.com/rv/wilmington+nc/forestriver+traveltrailer/1300/forest+river+r-pod+179
We decided on the desert. Wanted the seagrass though. Really looking forward to getting ours in about 5 weeks still.
------------- 2017 Nissan Pathfinder
RP-172 (on order)
Posted By: Subzilla
Date Posted: 29 Sep 2017 at 7:17am
The stone has been there for the last few years. We just got ours this past March in stone. Wilmington? Where do you live? We're 4 hours away just east of Charlotte.
------------- Mark
Concord, NC
Date Posted: 29 Sep 2017 at 10:26pm
Jacksonville. We've stayed in Concord a few times.
RP-172 (on order)
Posted By: Watts
Date Posted: 29 Sep 2017 at 10:43pm
What steps did you buy? Where?
Posted By: Wayword1
Date Posted: 30 Sep 2017 at 7:48am
We just completed our first camping trip with our 2018 182G and here is what I found.
1. The Furrion Bluetooth doesn't seem to do anything, but play radio.
We downloaded the app and connected nothing happens. Tried plugging in our iphones to play music - no results, tried to connect the tv to play external speakers, no results.
2. The double steps are nice and installing the Camco carpet quiets them down a lot.
3. The thermostat for the A/C is right below the unit. It would not maintain temperature on a hot day. If the side vent is open the A/C will shut down because it blows on the thermostat.
We closed the vent and put some aluminum tape about 2" above the stat which reduced the cycling and the unit had no problem keeping up with the sunny 90 degree days.
4. I strongly recommend anyone buying one of these to open all of the cavities - Forest River apparently does not clean up after themselves. We found loose pipe fittings, screws, pieces of wood and sawdust everywhere.
------------- Anne, Joe
and Quinn our Cairn Terrier
2017 182G
2017 Honda Ridgeline RTL-E
Posted By: mcarter
Date Posted: 30 Sep 2017 at 8:17am
Wayword1,
+1 to opening areas and cleaning construction debris. Look behind power convertor/fuse panel, under shower and be sure and flush/drain your fresh water tank. I had plastic debris in my fresh water tank, it gets sucked into the faucets, etc.
------------- Mike Carter
Posted By: Wayword1
Date Posted: 30 Sep 2017 at 9:45am
Thanks for the additional heads up. I did not look behind the power converter and will do that.
2017 182G
Posted By: DavMar
Date Posted: 03 Oct 2017 at 6:49pm
Originally posted by Wayword1
4. I strongly recommend anyone buying one of these to open all of the cavities - Forest River apparently does not clean up after themselves. We found loose pipe fittings, screws, pieces of wood and sawdust everywhere. |
So Wayword1 you dont think R=Pod will make the pages of Better Homes & Campers?
I agree, was kind of surprised with amount of building debris I found in mine. I guess FR hasn't discovered how to use a shop vac yet?
------------- Dave & Marlene J with Zoey the
wonder dog.
2017 Rpod 180
2016 Toyota Tacoma SR5 4x4
Lexington, NC
Posted By: Wayword1
Date Posted: 04 Oct 2017 at 7:25am
Better Homes? More like Do It Yourself Magazine. Thanks to this forum and pictures online we have learned a lot.
Just a little engineering could have improved the quality of these. A template on the floor where to drill holes would go a long way to provide extra space and minimize the sabre sawed holes.
As all things, we will make the best of it and enjoy the process.
2017 182G
Posted By: furpod
Date Posted: 04 Oct 2017 at 7:43am
Which model do you have? I have found when playing music over BT I often have to turn it up a bit, BT seems to transmit at a low "volume" BT ONLY does music/sound. You may need to select the input source manually on the head unit. I admit, we don't have this brand, but plenty of youtube videos show it's setup and use procedures. Also, because Bob may have been.... distracted... when assembling your unit, make sure the speaker and tv wires are actually hooked up on the back. We have seen them not be a few times. I like to think they somehow fell of in transport.. but..
We found this too, though I didn't think the steps were noisy, we added carpet for our elderly Golden to be able to get in easier.. the pup jumps them most times.. LOL. In the future, he will use them I am sure.
Has ALWAYS been a problem of some sort.. there is only so much room to put stuff and avoid other stuff, in a small camper. Many buy or build a small cover to "shade" the thermostat from the direct blast of the a/c when in that mode.
Pods are built to price point. It is what it is. Did I find construction debris in our Lance or Airstream? Nope. Do they cost hella more? Yep. Most owners never open those closed spaces. You would choke if you opened the walls of your home. Trust me on that.
Posted By: fwunder
Date Posted: 04 Oct 2017 at 9:33am
This made me chuckle! When we demoed and rebuilt our home we found countless chocking hazards in the walls! Mostly in the form of beer caps! The fellow who built the house had an unmistakable fondness for Schlitz! Lot's of old newspaper insulation and critter droppings too. In one wall we found a book - "Fun With Dick and Jane" - checked out of the local library in 1957. Afraid to return it.
Yeah, we found quite a bit of construction debris in our pod when exploring spaces. Vacuumed them up and moved on. It's not that big a space.
------------- 2014 RPod 178 => https://goo.gl/CV446f - MyMods and Buying Habits
Posted By: Wayword1
Date Posted: 04 Oct 2017 at 11:28am
As far as cleanliness verses price point, can't say I agree. It takes so little time to blow or vacuum out during construction, it would be an insignificant cost. The sawdust is just a indicator of quality in my book, but the loose screws that lodge under wiring and tubing becomes a hazard over time.
Yes I know what a home looks like in the walls and outlet boxes. My little shopvac is by my side during my projects.
I have noticed older models of the 182G people have placed drawers under the bunks. Thought that was a great idea, until I found our 2018 has a false wall and is used to run wiring and water lines. They stack up about 6 inches. I will have to lay them down flat on the floor and cover them for a built in drawer in that space. I wonder if older models had the wiring run under the floor?
Thanks for your post.
2017 182G
Posted By: furpod
Date Posted: 04 Oct 2017 at 12:52pm
A little time is a different thing in a factory..
Earlier 182's may have had them run differently, but I am pretty sure, not outside the cabin. But, I have not worked on any 182G's I don't think.
Posted By: Keith-N-Dar
Date Posted: 04 Oct 2017 at 1:41pm
I wish those who have opinions about the things FR should do or add would spend some time on the line at one of the plants. To hit the price points following the work with a vacuum is not possible. Neither is a more expensive axle, a quieter air conditioner, a different refrigerator or any of the other suggestions normally found at a site of this type. To have this come in at the cost we appreciate the specifications have to be different from more expensive product. As consumers we need to decide what we want.
------------- Keith-N-Dar
2011 R-Pod 177
2010 Ford F-150
Posted By: Richand Cindy
Date Posted: 04 Oct 2017 at 6:18pm
After every trip we enter the pod and the first thing we do is vacuum. It seems we are still getting wood shavings. Its not just the floor but also on the table so it is also coming from the cabinets above. Not a big deal but we just joke about will it ever end!
------------- OLD 2017.5 RPOD 180 + 2015 Jeep Cherokee Trailhawk
Posted By: rpodmybe
Date Posted: 29 Nov 2017 at 3:21pm
FWIW on the mess/clean-up, talking with my aunt and uncle who own a 5th wheel and who's friends all own nice 5th wheels. All started with travel trailers.
I was talking about all the issues I'd heard and they said, "it's a RV". Basically unless you're buying top 1-3 brands you're getting a fair bit of that. Probably moreso these days as many of the RV brands suffered downturns during the economy and now are trying to turn out units FAST to make money while times are good. They made it sounds 100% normal.
Regarding the radio, is this an "upgrade", a downgrade? just a change?
Posted By: Cassie
Date Posted: 01 Jan 2018 at 8:33am
I just got an rpod 176 in desert soooo nice! I traded in my 2018 176t it was the grey color. But I love the new colors. The blue is nice too.
Posted By: Cassie
Date Posted: 01 Jan 2018 at 8:39am
I think the manufacturer back east is tacky. I had a 2018 176 t that was full of screws and sawdust. I traded in the 176 t for a 176 and ordered a new one here on the west coast. It was 100% cleaner and fit and finish was much improved.
Posted By: Wayword1
Date Posted: 01 Jan 2018 at 10:37am
Thanks Cassie,
It is good to know there is someone who believes in giving the buyer a product that the builders take a little pride in presenting to a customer.
2017 182G
Posted By: GlueGuy
Date Posted: 01 Jan 2018 at 11:49am
Originally posted by Cassie
I think the manufacturer back east is tacky. I had a 2018 176 t that was full of screws and sawdust. I traded in the 176 t for a 176 and ordered a new one here on the west coast. It was 100% cleaner and fit and finish was much improved. | I think I agree with this opinion. Our (early )2017 R-179 (it's still green) has been clean in every hidden compartment that we've opened. So I think the detritus issue that I've read about on the forum may very well be confined to one or more production facilities, and is by no means a universal observation.
------------- bp
Date Posted: 01 Jan 2018 at 1:24pm
Or the dealer may be more interested in presenting a clean coach to the buyer.
2011 R-Pod 177
2010 Ford F-150
Posted By: GlueGuy
Date Posted: 01 Jan 2018 at 1:45pm
Or the dealer may be more interested in presenting a clean coach to the buyer. | That's certainly a possibility. At any rate, ours was really clean.
------------- bp
Posted By: jato
Date Posted: 01 Jan 2018 at 4:13pm
Have to agree with Keith-N-Dar. when we picked up our 177 back in March of 2011 it was spotless, the dealer went through all the cubbyholes with us showing us storage, ect. No debris or dust or wood shavings anywhere. Maybe it was the dealer as there seem to be more that complain about the opposite of what we experienced.
Posted By: mcarter
Date Posted: 01 Jan 2018 at 4:18pm
Mine had considerable debris in out of the way places, but I was second owner, I cleaned, so no one to blame but me now.
