Blackstone Grill
Forum Name: Miscellaneous / Off-topic
Forum Discription: Pull a chair up to the campfire and chat. No religious, political or weapons talk, please.
URL: http://www.rpod-owners.com/forum_posts.asp?TID=11709
Printed Date: 18 Apr 2024 at 7:29pm Software Version: Web Wiz Forums 9.64 - http://www.webwizforums.com
Topic: Blackstone Grill
Posted By: mjlrpod
Subject: Blackstone Grill
Date Posted: 10 Jun 2018 at 3:25pm
I bought 2 blackstone grills. I got the 17 inch to bring camping, and a 28 inch for home. I got them both seasoned and ready to go. Tonight, I'm breaking in the 28 inch grill with 2 succulent juicy porterhouse steaks. These things look awesome, and so much cheaper than other grills. I got my Webber Q 1000 for 200 bucks. It's a small grill, which I liked, but the 17 inch blackstone was only 60 bucks. Its just as big, maybe a tiny bit bigger, at about a third of the price. Can't wait to try them out.
------------- 2017.5 Rp-172
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Posted By: mcarter
Date Posted: 16 Jun 2018 at 8:07am
THANKS, also considering Blackstone and appreciate the kudos.
------------- Mike Carter
Posted By: furpod
Date Posted: 16 Jun 2018 at 8:32am
We have used our 17" several times now, including almost every day this week.. Between it and our GMG smoker, we have not cooked anything in the camper this trip.. Wife did make a P, B & J yesterday inside.. LOL
Posted By: mcarter
Date Posted: 16 Jun 2018 at 3:21pm
Thanks, Furpod, heard you mention same, buying today. BTW - made it home safe - Excellent Round Up.
Posted By: Podizzi
Date Posted: 17 Jun 2018 at 9:49am
Have you hooked these blackstones to the outside propane connection on the rpod or do you use the small propane bottles?
------------- Podizzi
2017 rpod 179
2016 Toyota Sequoia
Phoenix, AZ
Posted By: mcarter
Date Posted: 17 Jun 2018 at 9:53am
Podizzi,
Using small bottles, I do not have a outside propane connection on a 15 178. I did add a CAMCO adapter to propane tank for accessory use and I can use that to fuel grill.
Posted By: Podizzi
Date Posted: 17 Jun 2018 at 11:03am
Thanks Mike. Does Campco make a connection adapter for the rpod?
2017 rpod 179
2016 Toyota Sequoia
Phoenix, AZ
Posted By: mjlrpod
Date Posted: 17 Jun 2018 at 12:53pm
I run my grill, what ever type I use, straight from a 20 bottle. once or twice I had a one pound run out in the middle of cooking and didn't notice right away, that was enough for me. I don't use the external propane connection point for anything. I considered removing it, but havn't
2020 R-pod 195
I'll be rpodding
Posted By: furpod
Date Posted: 17 Jun 2018 at 3:05pm
Originally posted by Podizzi
Have you hooked these blackstones to the outside propane connection on the rpod or do you use the small propane bottles? |
We have hoses/connections so we can go high, or low, pressure, 20 or 1 pound bottle.
This last week at the ERU, I ran on the low pressure system. Our current TT mounts 3, 20pounders, and, has 2 low pressure connections. So we had the outside cooktop lit, the Blackstone griddle, and the GMG smoker (uses 12v and pellets), all going at once at a couple points.. and maybe even the microwave prepping a sauce..
Didn't do any dutch oven cooking, though others did..
Posted By: mcarter
Date Posted: 17 Jun 2018 at 4:32pm
Podizzi,
I don't have a low pressure connection on my Pod, and I don't care because I'm not going to modify my cookers to accept low pressure. I use a CAMCO adapter to add propane accessories which attaches directly to tank, that way I can use bottles or tanks. The regulator is on grill. Not quite sure why FR decided to add a low pressure propane adapter. No grill with a regulator works with it.
Posted By: mcarter
Date Posted: 25 Jun 2018 at 4:29pm
Last comment on Blackstone 17" grill. I noticed after several uses small rust spots on bottom of grill. After seasoning, I now lightly oil bottom of grill prior to cooking. The bottom of grill is also now seasoned. BTW - DO NOT paint with High Temp Rustoluem like displayed on Interweb, it is not made for contact with direct flame. Oil it turn it over and cook on it. Works fine.
