Rpod cover
URL: http://www.rpod-owners.com/forum_posts.asp?TID=12742
Printed Date: 04 May 2024 at 12:55am Software Version: Web Wiz Forums 9.64 - http://www.webwizforums.com
Topic: Rpod cover
Posted By: Gregm
Subject: Rpod cover
Date Posted: 07 Apr 2019 at 9:22am
Can anybody recommend a cover for a 2014 171 that will fit the pod. The pod has an AC unit and the last cover we bought did not fir. TIA
------------- Gregm
2014 171
2015 Toyota Tacoma Prerunner
Posted By: TearlessTom
Date Posted: 07 Apr 2019 at 9:35am
I bought one of these
https://www.harborfreight.com/29-ft-4-inch-x-19-ft-camouflage-tarp-67702.html
Not made for the Pod but thought for the price it was worth a try. should be able to drape over entire unit then maybe stake the sides or corners down. Plus the camo hoping to help hide from neighbors view as it sits under trees in shadows.
------------- Tearless Tom
2017 R-Pod 180
2014 Ford F-150 XLT 2WD 5.0
Posted By: crw8sr
Date Posted: 07 Apr 2019 at 10:46am
We have a Classic Accessories cover. Fits like a glove. Covers A/C, spare tire, slide out awning and awning.
------------- Chuck & Lyn
Izzy, Morkie. RIP
Zoe Joy & Gracie, Yorkie
2018 R Pod 190
2019 Traverse
Posted By: wooleeman
Date Posted: 07 Apr 2019 at 12:22pm
I've had a Classic Accessories cover for the past two years. Fits very well, you just have to remember to cover any sharp areas, ie.- gutters, antenna, etc prior to installing cover.
------------- 2022 RP-202
2016 RP-179 (Sold 9/2020)
2014 Silverado Crew Cab. 6-1/2' Bed
Golden Retriever (DOB 6/16/2020)
English Bulldog (RIP 6/15/2020)
Posted By: Gregm
Date Posted: 08 Apr 2019 at 5:20pm
Thans for the responses. We ordered from Classic Accessories
------------- Gregm
2014 171
Posted By: Toyanvil
Date Posted: 08 Apr 2019 at 7:38pm
We have a Classic Accessories cover and we put a beach towel over the TV antenna, or it will cut the cover.
Posted By: StephenH
Date Posted: 09 Apr 2019 at 9:39am
When we had the bat wing antenna, I cut sections of pool noodle to fit over the wings to protect the cover. Since replacing the bat wing with a flying saucer which does not have sharp edges, I don't need to do that. I still use sections of noodle over the rain gutter spouts over the slide-out to protect the cover there and some other small sections at the bottom corners to protect those areas. I did not put the cover on this winter as I did not have a chance to wash and wax it before the cold weather hit after we brought it home from having the axle replaced. One does need to watch out for anything that could snag the cover as it will tear.
------------- StephenH
Posted By: WillG
Date Posted: 22 May 2019 at 5:07pm
I'm looking to replace the original bat wing antenna - do you ming posting info about the saucer antenna you replaced yours with and any tips regarding install? - I know batwing has to cables red and coax thanks
------------- R-Podder by process of elimination
2014 RP179
2011 GMC CrewCab Short Bed
Posted By: StephenH
Date Posted: 22 May 2019 at 5:19pm
It is in my mods. In a nutshell, the one I ordered fit the existing mount so I could just bolt it on. I had to change the amplifier inside and to a bit of wiring since they were wired differently. Unfortunately, it looks like the one I got is not currently available. I can't say that what applied for the one I got would apply to one of a different brand.
