Tire rubbing fender . Looking for advice
Forum Name: I need HELP!!!
URL: http://www.rpod-owners.com/forum_posts.asp?TID=12792
Printed Date: 05 May 2024 at 2:52pm Software Version: Web Wiz Forums 9.64 - http://www.webwizforums.com
Topic: Tire rubbing fender . Looking for advice
Posted By: tent2pod
Subject: Tire rubbing fender . Looking for advice
Date Posted: 23 Apr 2019 at 7:07pm
Hello , We are now owners of a new to us 2018 R pod 178 . We brought it home 2 weeks ago . Looking at it closer at home I noticed a difference from the tire to the fender from one side to the other side . On the side opposite the slide out there is about 2 inches clearance from tire to fender . On the side of the slide out there is only an inch in some places . I pulled the wheel off on the slide out side to make sure it wasn't hitting the fender and i could see where it has rubbed . Looking at the wheel and axle I see no sign of anything being bent or broke . The tires that are on it show no uneven wear or unusual wear in them . I measure from the cement floor that its sitting on to the trailer and it shows around 1 inch lower on the slide out side which forest river tells me is ok . The fender is not centered to the wheel on either side , if it was I don't think it would rub .
I feel the 3 inch riser kit would solve the problem but Could something be wrong with the axle other than being bent . Or could it be just that the fender was not centered over the tire and the PO just ran it that way . Any thoughts and advice would be appreciated . ( We did not buy the service warranty yet it is not cheap )
Posted By: GlueGuy
Date Posted: 23 Apr 2019 at 7:32pm
Check the "clocking" on the torsion axle. It's possible the elastic inserts might be damaged on the slide-out side.
------------- bp
Posted By: tent2pod
Date Posted: 23 Apr 2019 at 7:57pm
what is the best way to check the clocking
Posted By: Tars Tarkas
Date Posted: 23 Apr 2019 at 8:51pm
Check everything else out, but I believe the fenders are usually different heights. The one on the road/slide side is lower to accommodate the slide. That said, it shouldn't rub the wheel (of course). I don't think Pod warranties are transferable, and yours might have expired anyway, but it sounds like a manufacturing defect that FR ought to fix, assuming it's not some other problem with the axle.
I recently had an explosive blowout on my slide-side tire going down the road. It blew the entire fender off completely and instantly. So I got a new one and put it on. Not a lot of trouble. Two times not a lot still isn't very much -- meaning taking the fender off and moving to a better position wouldn't be too hard, if that's what it comes to.
TT
------------- 2010 176
FJ Cruiser
Posted By: offgrid
Date Posted: 24 Apr 2019 at 8:17am
In addition to the starting angle of the torsion arm (aka the clocking) the axle itself might be bent but not obviously look like it. One way to tell is to look at the axle tube. It should have a little crown to it (center higher). About 3/16 or 1/4 inch is normal. You can run a string line along the bottom from end to end and measure the gap in the center. If it is flat or curves downward in the center it is bent. This could cause the rubbing or negative camber at the wheels on one or both sides. Not an unusual problem on rpods.
------------- 1994 Chinook Concourse
Posted By: tent2pod
Date Posted: 24 Apr 2019 at 12:03pm
I ran a string across the bottom of the axle today and it has about a 3/16 arc in the center high . I jacked both sides up and removed the wheels . Using a 24 inch scale laid across the top of the torsion arm and measuring from one end of the scale to frame then the other end of the scale to the frame . Doing this on both torsion arms to compare the readings . I can see where the torsion arm angle (clocking) on the slide out side is not the same as the angle on the opposite side . Should they be the same . And if so what would cause this . This camper is one year old and the tires show some wear but I don't think there are a whole lot of miles on it .
Posted By: GlueGuy
Date Posted: 24 Apr 2019 at 12:34pm
You might have hit a rough bump or something, plus the slide-out side is a bit heavier. The clocking is fixed at the factory, so the only thing I can think of is a manufacturing defect, or the previously mentioned elastic tubes inside the axle tube.
------------- bp
Posted By: offgrid
Date Posted: 24 Apr 2019 at 4:34pm
The 3/16 crown sound good.
If you measured the torque arm angles with no load on them then they should be the same. If the slide site is rotated significantly further upwards then I agree with GlueGuy, it sounds like probably the rubber cords which carry the axle torsion load have been over-compressed. I doubt that the axle tube itself could be twisted without a lot more load on it.
There is no way to fix that short of axle replacement as the cords are installed compressed and frozen using liquid nitrogen at the factory and allowed to thaw. While FR should take care of it they are saying that a 1 inch height difference is OK, which is pretty unreasonable I think. So I doubt they will take care of it under warranty, but you can try by arguing that as is the trailer isn't useable because its rubbing. If that is unsuccessful then unfortunately you'll likely have to buy a new axle if you want to get rid of the 1 inch height difference. Adding a lift kit is fine but doesn't fix your underlying problem.
If you have to pay for it yourself you might consider getting the next heavier load rated axle which would be 5200 lbs vs. 3500, but if you did you'd need different brake assemblies and 6 lug wheels as well as the axle itself. More $$. Lippert makes these axles so if you want to go that route you could contract them directly, FR and the dealer will I'm sure tell you you have to buy the same axle that's on there now. The 3500 lb axle is a bit weak for the application, if its any consolation you are not the first person to have had problems with them.
Posted By: Happy Tripping
Date Posted: 24 Apr 2019 at 5:19pm
I am very sorry to hear of your problem.
The 3500# axles are apparently 'industry standard', whatever that means, for trailers of the r-pod's weight. Our 171's axle got bent, somewhere. I've chosen to go thru tires at a 2x rate rather than spend the $$ to get a new axle. I have no idea whether or not that is a feasible option for you. If not, replacing the axle with a 3500# axle is probably your best option in terms of the cost/benefit ratio but there is no guarantee the axle won't get bent over time like ours did. Still, the odds are on your side, there are a lot of smaller trailers out there with 3500# axles that DON"T get bent.
Whatever, don't let this turn you off trailering, once you get past this admittedly nasty incident, get out there and I'm sure you will enjoy your trailer.
Posted By: Toyanvil
Date Posted: 24 Apr 2019 at 7:06pm
Are you saying your trailer is not level to the ground? of so, I would look for a frame repair shop in your town that works on trailers and have your trailer axle aligned, should be a round $200. and enjoy your trailer, that is what I did.
The real problem with the RPOD is the frame rails are to narrow for the axle and there is to much leverage. The frame rail to hub face is will over the 9 inch max recommended, mine is close to 14".
If your trailer wheels are not straight up or real close to it or are wearing tires odd, you should have it checked at a good frame shop.
Posted By: tent2pod
Date Posted: 24 Apr 2019 at 8:03pm
After making the checks that I did and reading all of your input the rubber cords being the problem makes a lot of sense to me . The two torsion arms are not at the same angle with no load on them . I did a lot of research on the r pods and was aware of the axles bending and I made sure there was no visual tilt to ether wheel or uneven tire wear signs before purchasing this one . I didn't read of the rubber cords being much of a problem . We have an appointment to have it looked at by the dealer that we bought it from next week . We are still super excited and can't wait to get out in it . It's just going to be a little later than we hoped but that is ok . Has anyone purchased and installed the axle them self .
Posted By: GlueGuy
Date Posted: 24 Apr 2019 at 8:48pm
Replacing the axle is not too big a deal if you are handy. There are only a few bolts to remove plus the brake wires. The biggest challenge is supporting the frame so you can remove the old one and install the new one.
------------- bp
Posted By: offgrid
Date Posted: 25 Apr 2019 at 7:01am
When supporting the frame the main thing is to spread out the load, the rPod frame rails are only 0.1 inch thick IIRC. Some 2x4's would probably do it. Lift behind the axle so you don't end up with the trailer coming up off the tougue jack.
I don't think an axle shop can help get a low cost fix in this case. You are not seeing the more common bent axle problem others have reported. That would show up as negative camber at the wheels and/or an axle tube that has lost its crown, neither of which you have.
In this case there are a couple of other possibilities besides damaged rubber cords. One is that it is possible that the axle tube has been twisted, although as I said I think that unlikely because tubes are very strong in resisting torsional stress. If you want to exclude that possibility comparing the angles of a couple of straight edges clamped to the flats at each end of the axle would probably work.
The other possibility is that the torsion rod inserted into the cords has twisted, in which case the fix is the same as for the cords themselves: new axle. If it were me and I was stuck putting a new axle under the trailer I wouldn't want to put back the same marginal part that couldn't handle the load in the first place, I'd go for a heavier axle. But that's me.
An inexpensive fix which you might find acceptable would be add about a 1/2 to 1 inch axle riser on the slide side. 1 inch height difference is pretty high but 1/2 inch is not at all unusual, my 179 is about 3/8 IIRC. After all, the trailer slide side is heavier so it will ineveitably site lower.
Good luck with the dealer and FR, please let us know what you end up doing.
Posted By: podwerkz
Date Posted: 25 Apr 2019 at 10:34am
As a general question, I wonder if it might be practical to beef-up the frame and have leaf-spring mounts welded on and install a regular trailer axle...I suspect the ride would be a bit rougher.
But it would last almost forever, and the spring pack can be tailored (even side-to-side) for the weight being carried.
------------- r・pod 171 gone but not forgotten!
Posted By: offgrid
Date Posted: 25 Apr 2019 at 4:42pm
Actually, everything else being equal, it looks like the frame load is worse with the torsion axle, because it applies both a force and a moment to the frame due to the torque produced by the torision arm. The spring axle only applies a force.
Here is an interesting article on the pros and cons of the two axle types:
https://echanicalelements.com/trailer-axle-springs-torsion-axle/ - https://echanicalelements.com/trailer-axle-springs-torsion-axle/
I suspect that keeping the ride height lower is probably the main reason FR uses torsion axles on the rPods. If you're going to lift the trailer anyway with a lift kit a spring axle might work ok.
Posted By: GlueGuy
Date Posted: 25 Apr 2019 at 5:12pm
Corrected link offgrid meant to send: https://mechanicalelements.com/trailer-axle-springs-torsion-axle/ - https://mechanicalelements.com/trailer-axle-springs-torsion-axle/
------------- bp
Posted By: StephenH
Date Posted: 25 Apr 2019 at 6:58pm
Originally posted by GlueGuy
Corrected link offgrid meant to send: https://mechanicalelements.com/trailer-axle-springs-torsion-axle/ - https://mechanicalelements.com/trailer-axle-springs-torsion-axle/ | Fascinating! I don't think a retrofit is possible for the 179 but it would not surprise me to see this appear sometime on a future line of travel trailers.
------------- StephenH
Posted By: lostagain
Date Posted: 25 Apr 2019 at 7:03pm
I'm glad my trailer tends to be on the lighter end of the rPod spectrum so I don't have as much risk of axle problems as those who have the heavier versions. I don't plan on ever buying another trailer, but if I did, I would certainly consider looking for leaf spring axle construction.
Fred & Maria Kearney
Sonoma 167RB
Our Pod 172
Posted By: offgrid
Date Posted: 26 Apr 2019 at 5:13am
I'm glad my trailer tends to be on the lighter end of the rPod spectrum so I don't have as much risk of axle problems as those who have the heavier versions. I don't plan on ever buying another trailer, but if I did, I would certainly consider looking for leaf spring axle construction. |
Sorry about the mmmissing "m"....
For a mechanical designer these considerations are important but assuming the designer has done his homework they are pretty much hypothetical for the trailer owner. Has anyone heard of someone who has bent the frame on their rPod in the way suggested by the stress model in the article? If not, FR/Lippert have spread the moment load from the torsion axle to the frame out enough that it hasn't been a problem.
Pretty much everything in engineering involves tradeoffs. Having the low ride height probably won out in their evaluation of the options, and in theory anyway the designers have adressed the drawbacks so they don't become our problems as owners.
Where we unquestionably do have problems is the axles themselves. Here the designers have pushed the limits a bit too far IMHO. We have the known problem with bent axles which is worsened by the inboard mounting points to the frame. That can be adressed fairly easily by axle reinforcement which a couple of us have done now in different ways.
Now we have tent2pod's issue which apparently is not a bent axle. So far we're just speculating about what it actually is, so I'm looking forward to a report once tent2pod gets to the bottom of it...
Re axle replacement, I have one other reason why i would go with a heavier axle if faced with replacement. Better braking. I think the braking action on the 3500 lb axle brake assemblies is marginal for my rig. Even at full voltage output from my brake controller I'm not able to get my trailer wheels to lock up when following the setup procedure specified for my Prodigy P2, and that is with brand new propery burnished brakes. For sure you back off from that point so you don't actually get lockup, but ideally you want to be just short of that point in an emergency stop.
The eTrailer tech I spoke to said this was pretty common with travel trailers. Anyone else have the same issue?
The 5200 lb axles have 12x2 inch brakes vs the 3500 lb's 10x2.25. If I did my math right that should result in about 12% more stopping power.
Posted By: furpod
Date Posted: 26 Apr 2019 at 9:05am
As a note.. Because of having to clear the movement of the slide, the slide side fender is mounted lower than the curb side...
Posted By: GlueGuy
Date Posted: 26 Apr 2019 at 9:41am
Originally posted by furpod
As a note.. Because of having to clear the movement of the slide, the slide side fender is mounted lower than the curb side... | Our RP-179 HRE has both fenders mounted at the same height. With the slide extended there is a minor difference in clearance; maybe about 1/2". That said, there is ~~ 2-1/2" clearance on the slide side and almost 3" on the non-slide side.
------------- bp
Posted By: john in idaho
Date Posted: 27 Apr 2019 at 9:22am
On my 179, the slide side has the fender mounted flush with the bottom of the trailer. The other side has the fender mounted flush with the top edge of the kedder rail. About an inch difference.
Posted By: GlueGuy
Date Posted: 27 Apr 2019 at 9:25am
Maybe it's the difference between HRE and non-HRE?
------------- bp
Posted By: StephenH
Date Posted: 27 Apr 2019 at 11:13am
Also depends on whether there is a keder rail or not. Mine does not so the fender is mounted the same on both sides.
Posted By: offgrid
Date Posted: 27 Apr 2019 at 11:34am
My 2015 Non-HRE 179 has the keder rail but it is not continuous, allowing the fenders to be the same height on both sides. So it looks like there are at least three different versions?
I was under the impression that Tent2pod's 1 inch side to side difference was to the trailer frame not to the fender but can you confirm?
Posted By: GlueGuy
Date Posted: 27 Apr 2019 at 12:39pm
Ours has the keder rail on the curb side, but there is a piece of trim under the slide out that is about the same width as the keder rail. The fender is mounted just a "skosh" above that trim piece.
------------- bp
Date Posted: 27 Apr 2019 at 12:51pm
Sounds like the position of the fender depends on who was building trailers that day. Ours is a west coast HRE .
Posted By: tent2pod
Date Posted: 27 Apr 2019 at 6:31pm
[/QUOTE]
Offgrid , I have it sitting on a cement floor . I checked air pressure in both tires making sure they are the same . Then measuring from the floor to the trailer right in front of each fender and at the back of each fender.
Posted By: offgrid
Date Posted: 28 Apr 2019 at 5:33am
Originally posted by tent2pod
Offgrid , I have it sitting on a cement floor . I checked air pressure in both tires making sure they are the same . Then measuring from the floor to the trailer right in front of each fender and at the back of each fender. |
Are your fenders the same height relative to the trailer frame? Put another way, is the 1 inch height difference entirely attributed to the axle or is part of it the placement of the fenders?
Posted By: tent2pod
Date Posted: 28 Apr 2019 at 12:04pm
The fenders appear to be the same height relative to the trailer frame .
Posted By: offgrid
Date Posted: 28 Apr 2019 at 12:12pm
Just checking to be sure i wasn't misunderstanding. Thanks
Posted By: tent2pod
Date Posted: 29 May 2019 at 8:03pm
Update on the axle . We took it back to the dealer that we bought it from , they are 85 miles away . They took it in to look at it while we waited. After about 20 minutes the service manager came out and told us they agreed that something wasn't right with it . He said it wasn't covered under warranty but seeing how we just purchased it from them he was going to take care of it . After about 15 more minutes he came back out and said lippert was sending a new axle at no charge and they would do the work at no charge , It was done a week ago but we weren't able to pick it up until yesterday. The slide side still sits lower than the non slide side which I would expect due to the weight of the slide , but its nothing like it was . Looks like they put the complete axle with hubs and all on . I asked if they had the old axle and he said lippert wanted it back to see what was wrong with it . So I have no answer for what the problem was with the old axle . I was happy with the Dealer (Avalon RV in Medina Ohio) for getting this done a big thank you to them and also to lippert for stepping up . In all the research that i have done on the R Pod this seems to be an isolated problem . We are looking forward to getting the new to us R Pod out but it won't be for a couple more weeks as my daughter is expecting any day now.
In the meantime I plan on greasing the wheel bearings on the new axle for my own peace of mind , Thank you all for your help.
Posted By: offgrid
Date Posted: 30 May 2019 at 4:39am
Glad it worked out well for you. You are right to expect the slide side to sit a bit lower. It sure would be interesting to know what was wrong with that axle, but I expect that will remain known only to Lippert.
Date Posted: 30 May 2019 at 8:42am
nice to see an RV dealer do what is right. Kudos to Avalon.
Sonoma 167RB
Our Pod 172
Posted By: Olddawgsrule
Date Posted: 11 Aug 2019 at 1:52pm
Originally posted by offgrid
[QUOTE=lostagain] Has anyone heard of someone who has bent the frame on their rPod in the way suggested by the stress model in the article? If not, FR/Lippert have spread the moment load from the torsion axle to the frame out enough that it hasn't been a problem.
Please don't tell me I'm the first!
------------- https://www.youtube.com/channel/UCJduGeZNFgtptH67leItRFQ - Byways no Highways
2017 Tacoma
http://tnttt.com/viewtopic.php?f=55&t=72408 - Truck Camper Build
2004 F150 My Overlander
Posted By: offgrid
Date Posted: 11 Aug 2019 at 2:58pm
The first I've heard of, but maybe some of our other members know of other incidents. In comparison, the axle problems have been much more common.
Both the axle and frame are similar enough in their load capacity though that it could just be the luck of the draw which fails first. One thing that can happen is that the first thing to fail absorbs enough of the energy that the second item doesn't wind up having a problem. That could be why your axle isn't that bad.
