New 195
URL: http://www.rpod-owners.com/forum_posts.asp?TID=14075
Printed Date: 03 May 2024 at 3:07pm Software Version: Web Wiz Forums 9.64 - http://www.webwizforums.com
Topic: New 195
Posted By: 1955Shoebox
Subject: New 195
Date Posted: 02 Oct 2020 at 12:34pm
Just joined the forum. We have a 2020 195 with Sandbar interior. Dual LP tanks and dual 12v batteries. Zamp portable solar panels for boondocking. Mods to date are removed the twin ottomans, changed the plastic pantry shelf brackets to metal, added another shelf in the pantry, added roll-out wire baskets in pantry, extended the bed to fit a real queen mattress, removed the hanging rod from the wardrobes and installed shelves, added doors under bed for access and installed wire basket roll-outs under the bed. Also changed the tires to Goodyear.
Love it
------------- 2020 R-POD 195
2019 Subaru Ascent
2015 Subaru Crosstrek Hybrid
1955 Chevy Belair Street Rod
Posted By: StephenH
Date Posted: 02 Oct 2020 at 1:28pm
Welcome and congratulations! I hope you have many fun adventures and make many great memories with your RPod.
------------- StephenH
Posted By: jato
Date Posted: 02 Oct 2020 at 7:22pm
Very Nice mods. Congratulations on your 195. Now it is time to get out and enjoy all those beautiful autumn colors that abound in your state!
------------- God's pod
Posted By: podwerkz
Date Posted: 02 Oct 2020 at 10:35pm
Hello, font police? calling the font police....font police, are you there? Hello?
------------- r・pod 171 gone but not forgotten!
Posted By: Pod_Geek
Date Posted: 03 Oct 2020 at 10:56am
Originally posted by podwerkz
Hello, font police? calling the font police....font police, are you there? Hello? |
Hey, at least it wasn't ALL CAPS...
------------- 2020.5 R-Pod 195 Hood River
2018 RAM 2500 6.4L
Posted By: Colonel Podder
Date Posted: 07 Oct 2020 at 8:37pm
Congratulations on the 195!
I have a 196 on order and would be interested in seeing pictures of the pantry and wardrobe mods.
Thanks.
Posted By: tewjax
Date Posted: 08 Nov 2020 at 8:10am
Congratulations and welcome! Did you do the mods or have them done? I'm especially interested in the dual tanks and batteries. And thanks for the font mod as I can read it! lol
Posted By: offgrid
Date Posted: 08 Nov 2020 at 9:10am
Be careful about adding dual cylinders and batteries, your tongue weight will go way up. Dual batts will add about 100 lbs and an additional cylinder about 40 lbs. If you need those mods you are probably a boon docker so might be carrying water too. Depending on what model you have that can add another 150-200 lbs to the tongue. You can easily end up well over 500 lbs, so be sure your tow vehicle is good for that.
For dual batteries most folks go with two 6V golf cart batteries in series. Battery size is GC2. You will need new battery cases as well, and a single battery jumper. These will fit in the existing battery rack without modification.
There are several mounting kits for dual cylinders available. You will need to remove the existing single tank and mount the new kit. You can get an automatic switchover too.
------------- 1994 Chinook Concourse
Posted By: Dirt Sifter
Date Posted: 08 Nov 2020 at 6:32pm
Nice mods. Double check to make sure the medicine cabinet is properly mounted to the studs and not just hanging on the 1/8" wall board. One fix you might consider, if changing the shelf brackets in the pantry hasn't already addressed it; I added quarter round in the corners inside the door frame on each side from just above the bottom shelf to just above the top one. The shelves kept sliding forward against the pantry door and blocking it till then. Also put a couple command hooks on the wall left of the sink to hang the sink cover on to get it out of the way and added a paper towel holder above the sink per DW's direction. Taking the ottomans out opens things up nicely. Can see why you put doors under the full queen bed; I just stored enough stuff there that it added too much to the tongue weight. Have fun!
------------- Greg n Deb 2020 195 HRE
Posted By: Ricktoon
Date Posted: 02 Jan 2021 at 12:45pm
Sounds like great mods. Do you have any pictures of extending the bed to fit the queen mattress and the doors under the bed?
------------- Rick and Ellen B
2019 Chevy Colorado
2021 Rpod 196
Posted By: RPodFan775
Date Posted: 11 Jun 2021 at 8:17pm
Hi 1955Shoebox, I want to replace those pantry shelf brackets too. Do you remember where you got them? They have to be kinda slim, and I didn’t find any that thin at Home Depot today. Thanks.
Posted By: mjlrpod
Date Posted: 12 Jun 2021 at 10:39am
I used these in the pantry, and in the wardrobes next to the bed. They have clips that can be adjusted about every half inch or so. I have had these in my pantry for two years and I put a lot of weight on my shelves. Can goods, water, etc.. never had a problem. You can get them at lowes/home depot too.https://www.amazon.com/Knape-Vogt-Shelf-Standard-length/dp/B001DT3158/ref=sr_1_94?crid=2YNLSKTV6QV0G&dchild=1&keywords=adjustable+shelf+brackets&qid=1623512011&sprefix=adjustable+shelf+br%2Caps%2C190&sr=8-94
------------- 2017.5 Rp-172
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Date Posted: 12 Jun 2021 at 2:39pm
Posted By: TheBum
Date Posted: 14 Jun 2021 at 11:13am
Originally posted by mjlrpod
I used these in the pantry, and in the wardrobes next to the bed. They have clips that can be adjusted about every half inch or so. I have had these in my pantry for two years and I put a lot of weight on my shelves. Can goods, water, etc.. never had a problem. You can get them at lowes/home depot too.https://www.amazon.com/Knape-Vogt-Shelf-Standard-length/dp/B001DT3158/ref=sr_1_94?crid=2YNLSKTV6QV0G&dchild=1&keywords=adjustable+shelf+brackets&qid=1623512011&sprefix=adjustable+shelf+br%2Caps%2C190&sr=8-94 |
We put that type of a shelf system in our 179 pantry and it has worked out well. We mounted the shelves upside-down to provide a lip at the front to help keep things from sliding out.
------------- Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
Date Posted: 14 Jun 2021 at 11:41am
Oh, I’ll check out the shelves and see if mine have a lip underneath. That’s a good idea!
I wish the fridge shelves had a lip. Our old 179 had that, but not this one, and sometimes our fridge is a jumbled mess when we get to camp. I’ll probably end up putting rods in there instead.
Posted By: TheBum
Date Posted: 14 Jun 2021 at 12:07pm
I use the dual Camco rods in the fridge. I also use them in the pantry to keep the tall stuff from tumbling over the shelf lip.
------------- Alan
Three cats
Posted By: mjlrpod
Date Posted: 14 Jun 2021 at 1:20pm
I use baskets in the pantry to keep stuff from flying. I have two baskets per shelf. They're 16 x 11 x 6, They fit great, and keep everything under control. I can actually put large boxes of cereal in back of them as well. Makes it easy to use all the space.
2020 R-pod 195
I'll be rpodding
Posted By: bemostue
Date Posted: 04 Aug 2021 at 4:10pm
We still had issues after replacing the plastic brackets with metal ones, in the pantry. The shelves collapsed. I'm thinking we'll have to use some kind of l-brackets and screw them in, even though they'll no longer be adjustable.
Posted By: bemostue
Any suggestions on how to clean the lower portion of the shower curtain? It seems complicated to remove it. Thanks!
Date Posted: 05 Aug 2021 at 10:24pm
We did the shelf fix also, and it improved things, but we still had a shelf fall now and again. But we can live with it.
Posted By: StephenH
Date Posted: 06 Aug 2021 at 7:16am
I've had plastic shelf supports that had a built-in clip that locks the shelves in place. It is longer and a springy tab is on the top of the shelf when it is in place and that keeps the shelf from being able to bounce up and off the support. I don't know what kind of supports FR used, and we don't have one in which to look. These are similar to the ones I have seen before which are light tan: https://smile.amazon.com/Plastic-Locking-Self-Locking-Support-Furniture/dp/B08SC2NPPD/ - https://smile.amazon.com/Plastic-Locking-Self-Locking-Support-Furniture/dp/B08SC2NPPD/
Posted By: TheBum
Date Posted: 06 Aug 2021 at 11:32am
I'll probably go with something like this after I get my 196, which is similar to the wire shelving system in my 179's pantry.
https://www.knapeandvogt.com/product-page/commercial-industrial-shelving - Wall-Mounted Adjustable Shelving Systems | KV - Knape & Vogt (knapeandvogt.com)
------------- Alan
Three cats
Date Posted: 13 Sep 2021 at 4:50pm
Hello again - sorry for the delay in responding. The mods we did can be seen in the attached photos. We replaced the plastic panty system with metal book shelf mounts from Rockler. You will need to mount a strip on one side as the metal system is thinner. Easy to do. Gives you much improved strength and flexibility for shelf location. Also added another shelf. Wire baskets are ELPA from the container store. Bottom slide mounts. Same system under the bed.
2019 Subaru Ascent
