The first time setting up was 45-50 minutes, the directions weren't the best IMHO. Regardless after doing this for 12 years it takes 15 minutes solo (not including the lower bug screen - that is a test of patience by itself). We normally don't use the lower screen. If this is your first time take your robertson screwdriver and make sure all the screws inside the keder rail are bottomed out, otherwise the channel on the dome will stick and make it laborious to pull through. Also, the first time (each year) out I will spray a light coat of silicone inside the keder rail, makes pulling the plastic channel on the dome quite easy. If you have 2 people this is the one place where I could utilize a 2nd person to help. One to feed the plastic channel into the keder and the other pulling the plastic channel to the other side. If you are doing this solo, as I usually do, simply lay the whole dome out straight so that when you begin to pull the plastic through the keder you aren't fighting the rest of the dome as you pull it to the other side. Keep door shut and hand rail in during this process. Some people utilize a step stool doing this. I am 5'10" and am tall enough to pull it far enough to get it to when I stand on the step to go in our 177 I can reach it and continue to pull to the other side.
Once that is done assemble your long radial pole (it must be 24' long or so) and slide that in the opening. There are a couple black straps to snap together along the outside edge of the dome, stick one end of the pole you just assembled into each end (you will find a metal ring with a hole inside). Next grab the 3 adjustable white poles, stick the ball end into the plastic receptacles on the dome, on the other end insert into the openings where you can see the metal pole. The middle one, being the highest can give you fits unless you have a stepstool or ladder UNLESS you insert that one first (on the outside side of the dome before doing the other two poles. Stretch it until the top of the dome material is taught, then do the same with the other two poles. Set your stakes, you are good to go.
As an example, last year we went on a month long trip to CO, UT, and AZ. For 1 or 2 nights we don't set it up but for 3 days or longer we do. It serves as a multipurpose room, protecting us or our road bikes from the elements if it rains, if the sun is very hot it offers shade. You have many options as far as which flaps go up, which stay down. Often we will even unzip the whole outer side so it is open and we can enjoy the spectacular view, we did that when in Rocky Mountain National Park (Moraine campground), North Rim, Grand Canyon as well as other campgrounds along the way. Often times when putting it away, it is wet so asap once arriving at your next destination open it up and hang it up to dry thoroughly, otherwise you know what damp mildew smells like.
------------- God's pod
