12 to 6 v battery switchout
Forum Name: I need HELP!!!
URL: http://www.rpod-owners.com/forum_posts.asp?TID=15538
Printed Date: 09 May 2024 at 9:52am Software Version: Web Wiz Forums 9.64 - http://www.webwizforums.com
Topic: 12 to 6 v battery switchout
Posted By: EchoGale
Subject: 12 to 6 v battery switchout
Date Posted: 05 Dec 2022 at 4:27pm
Greetings:
Three months ago I replaced my 12 volt batteries (I had 2) with 2 6 volt golf cart batteries. I checked and re-checked to be sure that they were connected properly in serial. They have been sitting for 2 months, water level checked, and battery disconnect switch off.
Today I checked them and found that they are dead. One is reading 0.0. and the other a little over 10. one has developed an small bulge in the top of the case. Costco can't check them or put a charge on them but the good news is that they said if I bring them in they'll just replace them!
Before I put the new ones in I want to make sure I didn't do something wrong that caused this. Did I need to make other changes for this switch from dual 12 to dual 6? Am I wrong that a couple of months sitting (while disconnected) shouldn't be a problem?
While I know they are dead because I tested them with my multimeter and because when I turned the disconnect switch on the lights weren't working, but is there anything different about using my multimeter on these batteries than there was on my 12 volt (also connected in series)?
Thanks for the help :)
------------- Julie
Posted By: Tars Tarkas
Date Posted: 05 Dec 2022 at 8:17pm
I'll be interested to hear how this sorts out. That's great about Costco replacing them! From what you've said, I don't see the problem. Two sixes in series is the same as 2 12s in parallel, as far as voltage is concerned. Were the batteries totally disconnected or were they connected with a disconnect switch in the circuit? Could be a bad switch.
TT
------------- 2010 176
FJ Cruiser
Posted By: StephenH
Date Posted: 05 Dec 2022 at 8:25pm
Flooded batteries will self-discharge. Even so, two months is rather short unless there was some load on them that you did not know about. How about the pin for the towing disconnect cable? Is it perchance pulled? That would put a heavy load on the batteries.
------------- StephenH
Posted By: EchoGale
Date Posted: 05 Dec 2022 at 8:38pm
Thanks to you both.
The batteries were connected and only "disconnected" via the disconnect switch, so if it is bad that would explain. I expect I can test that by hooking the new batteries up, setting the disconnect switch to "off" and then checking to see if my interior lights work. Right? If the switch is bad can it drain enough power to deplete the batteries while not enough for my lights to work?
I'll check that pin. These are good ideas but I can't check them out until at least Thursday. I'll keep checking here to add to my list of things to check and I'll report back. Thanks so much for the help.
Great about Costco though, right? I bet they won't do it more than once though ;)
------------- Julie
Posted By: offgrid
Date Posted: 06 Dec 2022 at 4:42am
It's quite possible that your batteries did self discharge in 3 months. You live in a hot climate which accelerates self discharge rates and golf cart deep cycle batteries self discharge faster than the typical dual use 12v ones. That's the price you pay for the deep cycle capability of the cart batteries. You need to keep them on charge every few weeks if not continously, and check the water level every couple of weeks as well, they consume more water when left on charge.
But first just to be sure you have the batteries connected up correctly.
Starting from the negative connection to the Rpod you should have that going to one battery's negative terminal. Then you should have a single jumper going from that battery positive to the other battery negative. Then from the second battery positive to the disconnect switch and then to the Rpod positive cable. And no other wires connected.
If that's the case and the disconnect switch was off then either the batteries were defective to begin with or they self discharged. You can eliminate the disconnect switch from consideration by first removing it's connection from the battery plus terminal. Put your multimeter on the ohms scale and connect it across the switch terminals. You should get an open circuit (or very high ohms) reading with the switch open. Then with the switch still disconnected from the battery close the switch and measure the ohms again. You should get a reading in the 0 to 1 or so ohms range.
------------- 1994 Chinook Concourse
Posted By: SC for Huskers
Date Posted: 06 Dec 2022 at 9:07pm
My old shut off switch had "1" or "2" or "Both" . Thus both 12v batteries went to the switch. I replaced the switch when I converted to the 6v batteries. Leave this tid bit up to the electricians.
------------- Happy Traveling,
Tom
2017 172pod
2011 F150 STX
Posted By: offgrid
Date Posted: 07 Dec 2022 at 1:48am
Let's not overcomplicate things, you really don't need to be an electrical engineer to set up an rpod battery system.
The dual battery 1-2-both-off switches are generally intended to switch between house and start batteries on a motorized RV or boat. You don't need that for a trailer with two paralleled 12v batteries, it's fine to just leave those connected to each other. If you want, you can get a simple isolator switch to disconnect the batteries from the house loads when the trailer is not in use, but then you need to consider that lead acid batteries cannot be left uncharged for long periods, which is likely what happened to the OP here.
Alternatives (depending on your storage situation): leave the trailer connected to shore power or connect to shore power for a day or so every few weeks and let the converter maintain battery charge. install a small solar module and charge controller remove the house batteries in the off season and maintain them at home on a small charger. o
Posted By: hogone
Date Posted: 07 Dec 2022 at 5:38am
Probably a goofy battery question but will ask anyway!! When Im home, I leave the old pod plugged in 24/7. Should I disconnect occassionally (maybe for a week or two) just to let the batterys drain a little? jon
------------- Jon & Pam
2013 RP177
2010 F150
2017 HD Streetglide
2009 HD Lowrider
CHEESEHEAD
Posted By: jato
Date Posted: 07 Dec 2022 at 7:03am
Originally posted by hogone
Probably a goofy battery question but will ask anyway!! When Im home, I leave the old pod plugged in 24/7. Should I disconnect occassionally (maybe for a week or two) just to let the batterys drain a little? jon |
Though I remove batteries during winter I read of many who keep their pods plugged in 24/7 for long periods of time without any ill effects. The only word of caution that could be added here would be to keep an eye on electrolyte levels (once/month) and fill with distilled water when needed.
------------- God's pod
Posted By: lostagain
Date Posted: 07 Dec 2022 at 7:17am
We keep our trailer plugged in all year and have been doing so since we first bought ourPod. The batteries have been fine and when I've periodically checked the water level, it was always where it should be except in the NV summer heat, when it dropped a tad.
Fred & Maria Kearney
Sonoma 167RB
Our Pod 172
Posted By: EchoGale
Date Posted: 07 Dec 2022 at 7:35am
Again, thanks so much for al the help. I'll be able to pursue the suggestions later today (I hope). Some follow-up points:
1) They sat for just under two months
2) After a couple of years of reading about the 6 v batteries I never saw that they can discharger faster, I wish I had as I might not have done it because my camper is parked where I cannot plug it in.
3) I don't have an "off season" so I guess I'll try to get a solar tender.
3) I have this same kind of disconnect switch and I keep it set on "off" or "both"
One day I'm going to make it to a rally in hopes of having someone teach me to use my multimeter. I only know how to test the charge on my batteries. This is way beyond my capabilities (honestly, with I can't even read this lol): " Put your multimeter on the ohms scale and connect it across the switch terminals. You should get an open circuit (or very high ohms) reading with the switch open. Then with the switch still disconnected from the battery close the switch and measure the ohms again. You should get a reading in the 0 to 1 or so ohms range." Just for fun I put the terms I don't understand in italics. :)
You all have been awesome as always; I'll report back.
------------- Julie
Posted By: hogone
Date Posted: 07 Dec 2022 at 8:09am
Im with you EchoGale!!! Multimeters are way beyond me (BTW, I had to spend 2 years in kindergarten!!). jon
2013 RP177
2010 F150
2017 HD Streetglide
2009 HD Lowrider
CHEESEHEAD
Posted By: StephenH
Date Posted: 07 Dec 2022 at 8:33am
Okay. I think I can help with this.
Ohms scale: On your meter, you should have a dial with various things like DCV (Direct Current Volts), ACV (Alternating Current Volts - your usual house plugs are 120V AC), DCA (DC Amperes), ACA (AC Amperes), Ohms (May be on the dial as a Greek letter Ω (Omega) which is the symbol for Ohms) and possibly battery test and transistor test functions. Ohms may be divided into 2000k, 200k, 20k, 2000, and 200 Ohms. Your meter may be different. Ohms is the symbol used to measure resistance.
Take the multimeter and put it on one of the Ohms settings. You should have a reading of 1, which indicates that there is no current flowing. Touch the tips together. The digital display should change to 0.00 for digital or the needle should move to 0 on the OHMS scale on a meter with a dial and needle. That is what indicates that there is a closed circuit and that current is flowing. If the reading is anything but zero, then that is the resistance of the circuit.
your battery switch should have three connections. One goes to one battery, one to the second battery, and the third to the load (the trailer wiring). With the batteries disconnected, turn the switch to Off. Put one probe on the terminal that leads to the load. Touch the other two terminals, one at a time with the other probe. The reading should stay at 1 (or very high on an analog meter). Turn the switch to battery 1. Again, one probe goes to the load, the other to the terminal for battery 1. The meter should move to 0 or very close to it. Touch 2 and it should stay at 1. Move the switch to battery 2. Again, one probe goes to the load and the other probe goes to the battery 2 terminal. The reading should be 0 or close to it. Then touch the Battery 1 terminal. The battery 1 terminal should remain at 1. Last, turn the switch to Off. Touch the Battery 1 and Battery 2 connections. The reading should remain at 1. If all these give you the results I mentioned, then your switch is functioning normally.
I hope this helps clarify for you what was meant.
Posted By: EchoGale
Date Posted: 07 Dec 2022 at 11:49am
Stephen this is very kind of you and I will try but, I know its hard for you to fathom because it seems so obvious to you, but this is still over my head. Like I do not know what a terminal is. I'm not asking you to explain, just trying to communicate why I don't completely understand. We live on different planets. :)
------------- Julie
Posted By: GlueGuy
Date Posted: 07 Dec 2022 at 3:24pm
We keep our trailer plugged in all year and have been doing so since we first bought ourPod. The batteries have been fine and when I've periodically checked the water level, it was always where it should be except in the NV summer heat, when it dropped a tad. |
+1 Same. I do have a reminder every 3 months to check the water.
When we stored our Rpod in a storage facility for a while, we pulled the batteries and kept them on a bench. That was a bit of a pain, as I would put them on a charger periodically. I guess you could also put them on a trickle charger, which is not an expensive proposition.
------------- bp
Posted By: StephenH
Date Posted: 07 Dec 2022 at 3:51pm
Originally posted by EchoGale
Stephen this is very kind of you and I will try but, I know its hard for you to fathom because it seems so obvious to you, but this is still over my head. Like I do not know what a terminal is. I'm not asking you to explain, just trying to communicate why I don't completely understand. We live on different planets. :) |
A terminal is a place where a wire attaches. The wire terminates there. Thus, terminal. If a wire does not attach to anything, nothing happens. I would like to help you understand. Thanks for letting me know that I left that part out of my previous reply. We all start from somewhere. There was a time when I did not know what a terminal was either or many other things.
Posted By: hogone
Date Posted: 07 Dec 2022 at 4:54pm
Oh my, all this talk on batterys got me thinkin. I bought two 6 volts about 3 years ago, and for some strange reason I always thought they were sealed. So I decided tonight I would be curious and check. NOPE!!!! Used over a gallon of distilled water topping them off. Dam, my parents should of kept me in 3 years of kindergarten. Obviously 2 wasnt enough!! jon
2013 RP177
2010 F150
2017 HD Streetglide
2009 HD Lowrider
CHEESEHEAD
Posted By: StephenH
Date Posted: 07 Dec 2022 at 5:08pm
Good thing you checked. A gallon of distilled water is a lot of water. They must have been quite low.
Posted By: hogone
Date Posted: 07 Dec 2022 at 5:15pm
Ya, I would say over a gallon is quite a bit!! I'm sure I have degraded them. I do have another question. I am only assumming batteries are intially filled with battery acid. I recall when I was younger when I would by motorcycle batterys, the acid came in a separate container and you would fill the battery yourself. I have always known to top off with distilled water, but why water instead of acid?? jon
2013 RP177
2010 F150
2017 HD Streetglide
2009 HD Lowrider
CHEESEHEAD
Posted By: StephenH
Date Posted: 07 Dec 2022 at 7:15pm
Why? Because as the water is turned to oxygen and hydrogen as the battery charges or evaporates from heat, the sulfuric acid becomes more and more concentrated. Adding distilled water restores it to the proper dilution for proper operation.
Posted By: jato
Date Posted: 07 Dec 2022 at 9:12pm
If you added a gallon to 2 batteries, they may have been hurt. I would think the plates would not have been covered by liquid at this point. Best bet at this point would be to give them each a 2 amp trickle charge for a couple days each. Read with you multi tester the voltage, they should read 6.36 volts if fully charged. Then read it a day later, it should still read the same or close to it, within 0.05 volts.
Posted By: offgrid
Date Posted: 08 Dec 2022 at 12:50am
Echogale, maybe try this video, see if that clears some of this up. Look particularly at the ohms and continuity sections. Checking a switch function is really a continuity check, either the switch is acting like a continuous piece of wire or its acting like two pieces of wire that are disconnected.
https://youtu.be/ciyWwcKmPC4
One thing that often helps electrical newbies is to think of your electric circuits as if they are water pipes. Voltage is like water pressure, pushing electricity through the wire. Current (amps) is l the rate the electricity flows through the pipes. Resistance (ohms) is the restriction of the wire (or load device) resisting the flow of electricity - skinny wire = more resistance so less amps, just like a skinny pipe will flow less water.
I suggest caution to start with when leaving your batteries on the on board converter continuously on charge. Check the water level in them frequently (like once a week frequently) until you get a good feel for how much they are consuming. Don't just connect and leave them for a month or two.
When a flooded type lead acid battery is floating on charge it is continuously converting water into oxygen and hydrogen (called electrolysis). You will see small bubbles in the cells when you look. That's good because the bubbles act to keep the acid mixed with the water in the cells. Otherwise the sulfuric acid, being much heavier, settles to the bottom, eventually causing degradation to the lead plates in the battery. But too much bubbling is bad, just consumes water needlessly and risks exposing the plates.
The amount of gassing (bubbling) is proportional to the amount of current being forced through the cells by the converter, and the higher the voltage setting of the converter the more current.The gassing rate is also effected by temperature (hotter = higher) and the details of the chemistry used in the battery manufacture). So it's hard to know in advance what your water consumption/gassing rate will be.
What happened to me was that my WFCO converter got stuck in it's "boost" stage and set it's voltage way up around 15V. It probably will surprise no one here to know that FR hasn't necessarily selected the highest quality converter for their trailers...
15V is way too high for continuous charging and consumed my battery water rapidly. In just a few weeks I went from completely full cells to barely covered plates. Caught it in time, no harm done as long as the plates aren't exposed . So the warning is, be cautious and check water level often till you have a feel for how fast you're consuming water.
Re filling new batteries with acid instead of water, that is a one time thing only. Often lead acid batteries are filled with acid at the factory, fully charged, then the acid is drained and placed in a separate container. This is called dry charging a battery and is done to increase it's initial shelf life and to improve safety during shipment There is no (well, very little) self discharge if the battery doesn't have electrolyte in it, if it it takes months before the end customer gets it installed there is no harm done.
But once you fill the battery one time with acid youre done. It won't consume acid over time, just water, so if you pour in more acid later you'll just be steadily increasing the acidity beyond what the battery is designed for. And that's bad because the higher acidity will cause more internal corrosion and result in shorter battery life. So, distilled water only please!
Posted By: hogone
Date Posted: 08 Dec 2022 at 5:46am
Oh, my plates were definately exposed; beyond exposed!! Will follow Jatos advice. jon
2013 RP177
2010 F150
2017 HD Streetglide
2009 HD Lowrider
CHEESEHEAD
Posted By: offgrid
Date Posted: 08 Dec 2022 at 6:47am
When the plates get exposed to air the sulfate that has been deposited on them from the sulfuric acid during normal discharging can harden up and become a permanent barrier, basically take the exposed part of the plates out of commission.
In that case you might see your battery voltage look ok but if you put any kind of load on the battery it dies quickly.
One thing that sometimes works in that case is "desulfation". In desulfation you take the battery up to a high voltage, like around 16V, hold it there for a little then cut off the charging for awhile, then repeat. That works to mechanically cycle the plates and might possibly break the sulfate loose,freeing up more plate area.
So you could try that if you have an old school battery charger that can be set to charge at a high voltage. I wouldn't hold out a lot of hope though after 3 years.
Posted By: jato
Date Posted: 08 Dec 2022 at 6:55am
Jon, please keep us abreast of your battery situation. Yes, as Offgrid points out, your batteries have been hurt due to the fact that the plates were exposed (for who knows how long) to air.
As I think about the electric carts we had at one of our 4 golf courses we went through a fair amount of distilled water! Each 6 volt battery holds just north of 1.5 gallons of liquid. Multiply that times 6 and you find yourself transporting over 9 gallons. But that is old school. Yamaha I believe was the first cart manufacturer to come out with the 48 volt system for golf carts; using six 8 volt batteries. The 8 volt batteries (Trojan) weigh about 1-2 lbs more than their 6 volt brothers but I think the liquid capacity is about the same.
Last year our oldest 12v Interstate (it was over 11 years old) was replaced with a Trojan T-1275, which is a 12v golf cart battery putting out 150aH, not light at 85 lbs, but has performed well so far with our nearly 12 year old original Interstate 12 volt. Each is run separately from the other.
Posted By: hogone
Date Posted: 08 Dec 2022 at 8:08am
Will def keep everyone updated. BTW, I have 2 Duracells; SLIGC115/6V 230AH. Stay tuned. jon
2013 RP177
2010 F150
2017 HD Streetglide
2009 HD Lowrider
CHEESEHEAD
Posted By: EchoGale
Date Posted: 16 Dec 2022 at 7:34am
Work got in my way and I didn't get pack to messing wiht the pod batteries as soon as I'd hoped. I followed Offgrid's instructions to be sure the wiring is correct and everything works as it should.
I have been checking the water level and have needed to add water a good bit more than with my old batteries so I think that likely was the problem.
there is an extra wire with both positive and negative connections it's thin. I bought my rpod used and its been there all along and have assumed it was the zamp wiring and I don't use it. Wouldn't mind alternatve guesses if you have any.
Heading out Sunday for a couple of weeks; thanks again for all the help.
------------- Julie
Posted By: StephenH
Date Posted: 16 Dec 2022 at 9:15am
Hello Julie,
That is exactly what they are. If you are not using the Zamp connector, you can leave them disconnected.
Posted By: offgrid
Date Posted: 16 Dec 2022 at 12:27pm
+1. Better to leave them disconnected if unused, less risk of a short that way.
And yes, flooded deep cycle golf cart batteries have a higher self discharge rate and consume more water. That is the tradeoff you make for better ability to handle deep cycling compared to SLI (starter, lights, ignition) auto batteries, or dual use marine type batteries..
Posted By: Colt
Date Posted: 01 Jan 2023 at 1:17pm
No. If your charger/maintainer, aka converter is good, it will switch to float charge voltage and maintain the battery. You need to check the water every month or @.
------------- John
'16 R-Pod 180
Posted By: Colt
Date Posted: 01 Jan 2023 at 1:22pm
Work got in my way and I didn't get pack to messing wiht the pod batteries as soon as I'd hoped. I followed Offgrid's instructions to be sure the wiring is correct and everything works as it should.I have been checking the water level and have needed to add water a good bit more than with my old batteries so I think that likely was the problem. there is an extra wire with both positive and negative connections it's thin. I bought my rpod used and its been there all along and have assumed it was the zamp wiring and I don't use it. Wouldn't mind alternatve guesses if you have any. Heading out Sunday for a couple of weeks; thanks again for all the help. |
I have an extra pair of wires, too. They go to the tongue jack and don't go through the disconnect switch. The jack has a light on it.
A simple solution is a 25 watt or higher solar panel to maintain the batteries.
------------- John
'16 R-Pod 180
Posted By: EchoGale
Date Posted: 02 Jan 2023 at 10:38am
Just a final update on all this: the new 6 volt batteries are working properly and they're great!
I've been all over Florida in the last couple of weeks including almost a week of dry camping with very little power discharge. FWIW, since I can only stay out as long as the house batteries last-- or are successfully recharged with my solar panel--I'm very careful about power usage and many of my little things have their own rechargeable/replaceable batteries.
I think with my new batteries I can stay out for weeks. :)
I think the problem was the water level as I had not understood that my maintenance routine needed to be modified from the old 12v batteries.
Thanks again for the tutoring. :)
------------- Julie
Date Posted: 02 Jan 2023 at 11:23am
Nice to hear that you got your battery problems fixed. Have safe travels in the new year.
Sonoma 167RB
Our Pod 172
Posted By: offgrid
Date Posted: 02 Jan 2023 at 11:32am
EchoGale that all sounds great. Just one thing, when you say "as long as the house batteries last" shouldn't mean that you're taking them all the way down to full discharge. That will kill even deep cycle batteries pretty quickly. Shoot for more like 50% SOC (state of charge) max unless it's an emergency. That will be somewhere around 12.2V on your multimeter when the batteries have been left open circuited (unloaded and not charging) awhile.
Posted By: EchoGale
Date Posted: 02 Jan 2023 at 1:04pm
Thanks, no I don't mean complete discharge. I was, however, under the impression that the 6V golf cart batteries could be discharged down more than that though. Am I mistaken?
------------- Julie
Posted By: jato
Date Posted: 02 Jan 2023 at 9:16pm
Thanks, no I don't mean complete discharge. I was, however, under the impression that the 6V golf cart batteries could be discharged down more than that though. Am I mistaken? |
A single 6v battery can safely be taken down to 6.1v (50% S.O.C.) without damaging it. If you are reading the meter with both batteries hooked together than what offgrid states (12.2v) is correct.
Yes, please keep an eye on the electrolyte levels, keep filled with distilled water only. My oldest 12v battery (Interstate deep cycle group size 24) will turn 12 years old in 3 months. Proper care and maintenance is key with battery life/longevity.
Posted By: offgrid
Date Posted: 03 Jan 2023 at 2:23am
EchoGale, yes, deep cycle golf cart batteries will tolerate more and deeper cycles than SLI (starter, lights ignition (aka auto batteries) or dual use (aka marine) batteries. But of course tolerating the cycles isn't the same thing as liking them. So with any lead acid battery, around 50% is about as deep as you want to plan to go on a daily basis if you want to get some life out of them.
That being said, since you live in a hot climate your battery life will be relatively shorter because what's called shelf life (aka corrosion life). This is just inherent in lead acid batteries because the sufuric acid is constantly corroding the lead plates, and the hotter it is the faster the corrosion rate. So you won't get Jato's Michigan climate battery longevity in FL. Plus deep cycle batteries usually corrode faster than SLI batteries because the chemistry is optimized for cycling rather than shelf life. It's a trade off like most things in life.
Probably you won't get more than about 4 years out of your golf cart batteries where you live even if you're really careful about cycle depth.
Long story short, don't be afraid to cycle the batteries you have now when you need to, while avoiding going below about 50% as you can. Hope that's clear.
So, don't
Posted By: jato
Date Posted: 03 Jan 2023 at 11:58am
An interesting caveat to this who discussion is how long golf cart batteries last in golf carts. Here in the north country we would be replacing batteries after three seasons, and the season lasts 7 months or a touch longer. However those exact same batteries in the same name-brand and year golf cart will easily last 4 or 5 seasons in Florida where they are basically run all year long. Or looking at it this way, in Florida those batteries will give up to 60 months of service before replacement whereas in Michigan you only get 21 months of service. Our maintenance on batteries was stellar, keeping batteries clean, keeping an eye on electrolyte levels and filling with distilled water when necessary, keeping contacts corrosion free, charging cart after every 36 holes of play. Have not been able to figure out why the difference in battery life since as has been noted, the life of the battery ought to be longer in cooler climes (as the batteries owned by me attest to) than in warmer areas such as Florida.
Posted By: StephenH
Date Posted: 03 Jan 2023 at 12:03pm
Could the difference be the consistent use in Florida as opposed to the periods of non-use in Michigan?
Posted By: offgrid
Date Posted: 04 Jan 2023 at 7:03am
I think there are a few things related the Jato's truly exceptional battery life vs typical golf cart deep cycle lifetimes. Most people get 3 to 5 years from golf cart batteries.
1) SLI and dual use "marine" batteries have a different chemistries from deep cycle lead acid batteries. IIRC the deep cycle batteries use a lead antimony alloy which makes the plates more phyically robust (so they can handle the mechanical effects of deep cycling which consumes and redeposits the lead on the plates). But the antimony makes for higher self discharge rates. Also deep cycle batteries usually use higher specific gravity sulfuric acid (so that there is more acid there to be consumed during discharge). Both those chemistry differences increase deep cycle battery internal corrosion rates vs SLIs so shorten their shelf life.
2) There is a rule of thumb chemists use to assess the effect of temperature on reaction rates. That is roughly, to assume a doubling of reaction rate for every 10C temp rise. Internal corrosion in a battery is just another chemical reaction so if a battery in Michigan is 10C colder than a battery in FL it should last twice as long everything else being equal. And looking at annual average temp is misleading because the doubling corrosion rate factor is an exponential function, meaning that the extreme temps high and low will tend to dominate lifetime, not the averages.
3, jato is clearly an expert on how to manage batteries from his long experience with golf cart maintenance, plus he is very careful in monitoring hus battery system state of charge.
4) And yes he has a shorter use season than EchoGale does.
So he is able to extract more life from his batteries than pretty much anyone. Including me, I'm not anywhere near as careful as jato is and live in a warmer climate, and run deep cycle golf cart batteries not SLIs or "marine" batts. So I've always hitting the 4 or 5 year lifetimes too. The way I look at it golf cart batteries are kind of an insurance policy for those of us who aren't going to be perfect in our battery management techniques and will wind up deep cycling them more than we'd like from time to time.
Of course Li batteries blow away PbA's in all these areas and theyre so cheap now that for those of us who are a bit electrically handy they have become a almost a compelling upgrade. And since it's mandatory that Li's have a BMS for safety, you do t need to be a super conscientious operator as much with them. The BMS provides that last line of defense fircyou automatically.
Posted By: StephenH
Date Posted: 04 Jan 2023 at 10:19am
Originally posted by offgrid
Of course Li batteries blow away PbA's in all these areas and theyre so cheap now that for those of us who are a bit electrically handy they have become a almost a compelling upgrade. And since it's mandatory that Li's have a BMS for safety, you do t need to be a super conscientious operator as much with them. The BMS provides that last line of defense fircyou automatically. | The BMS is one reason I really like my LiFePO4 battery setup. I don't have to worry about damaging my batteries or about adding water or other maintenance issues. Plus, I can have them inside where they are protected against the extremes of weather and against the one who would pilfer them off the A frame if they were outside.
The price has dropped tremendously if you don't go for the big names such as the one that has two of the letter B in its name. Even it has come down below $900 but it is still on the high end for 100Ah LiFePO4 batteries.
Posted By: offgrid
Date Posted: 04 Jan 2023 at 12:23pm
Check out some of the Li battery tear down videos on YouTube. What's in there is just bunch of Li cells and a BMS. So you can just buy the Li cells and a BMS and make your own. Pretty easy, plus you get Bluetooth access to the BMS setpoints and datal if you want to track or change anything. If you do it that was the cost is around $700 for a 280ah, 12V battery.
Being lithium about 80% of that capacity is useable so 280ah is roughly equivalent to 2 series (edit) x 2 parallel 220ah golf cart batteries used down to 50% SOC, which will set you back about (edit) $600-700. So lithium batteries are really now (edit) about the same cost as low cost flooded lead acid. Not (edit) even considering all the benefits.
Posted By: StephenH
Date Posted: 04 Jan 2023 at 1:11pm
Not to mention the life should be much, much longer than the GC2 batteries. In the long run, the LiFePO4 batteries should be much less expensive although the up-front cost is higher.
Posted By: offgrid
Date Posted: 04 Jan 2023 at 6:01pm
Whups, I had a math error in my previous post, (corrected). One DIY 12V (actually 13.2V) LiPO battery is the equivalent of four 6V GC2 batteries, not 2. So LiPO can now be as cheap as low cost golf cart batteries. Not to mention the longevity (4x or more), efficiency (around 10% better) and weight (1/5) advantages. And they don't emit dangerous or noxious gasses either, so you can keep them inside the cabin if you want to. And that solves the only real issue with them which is keeping them warm in sub freezing weather. Other advantages: negligible self discharge and no multi stage charge protocol like lead acid has.
The weight factor is critical if you want a high power system to run a/cs or other big loads. As an example, right now I'm planning a 48V 280ah system for my new to me RV, that's the equivalent of 16 GC2 batteries but will weight in under 200lbs vs half a ton of lead acid batts, which would of course be impossible.
