Axle Lifter Option
URL: http://www.rpod-owners.com/forum_posts.asp?TID=1967
Printed Date: 20 May 2024 at 3:31pm Software Version: Web Wiz Forums 9.64 - http://www.webwizforums.com
Topic: Axle Lifter Option
Posted By: Footslogger03
Subject: Axle Lifter Option
Date Posted: 22 Jul 2011 at 11:08am
Anyone here have the option that raises the R-Pod another 3" off ofmthe ground ? We live in Wyoming and some of the roads leading in/out of the campgrounds are a tad hilly and bumpy, to say the least. When we visited a dealer a week or so ago the salesman thought that the "Axle Lifter" option might be a good idea ...and I just wanted to get some frank feedback from other R-Pod owners. If it matters any, we are looking at the 177 model.
Thanks in advance,
MJ
------------- Livin' the Dream ...'Slogger
Posted By: Podsible Dream
Date Posted: 22 Jul 2011 at 11:55am
The only way to go! if you search the forums on axle lifter you will find many tales of woe from folks before they got them installed. I heartily recommend them, they make even in and out of the driveway less nerve wracking.
------------- Chris and Walt
'10 RP-171 'Free Spirit'
Posted By: techntrek
Date Posted: 22 Jul 2011 at 12:05pm
We have several threads on the risers, a quick search will bring them up. They can be ordered from FR for about $75, where most dealers want twice that or more just for the parts. Then add labor. If you have a good floor jack and some jack stands you can do it yourself in an hour or so.
Date Posted: 22 Jul 2011 at 12:24pm
YUP ...the dealer who mentioned them wanted $200 (installed)
Thanks for the tip !
MJ
Posted By: ka9nyn
Date Posted: 23 Jul 2011 at 7:35pm
Keep in mind, the risers only raise the coach, not the axle. So axle to ground will remain the same. I'm going to install them in a week. FYI...
------------- Dave & Rose
RP177 "ECM-Pod"
'08 Dodge RAM quad cab 5.7L 4WD "Rhino (re: F-4 Phantom)"
Chamberlain, SD (Formerly: Rockford, IL)
2010 RP 177
Posted By: Hodge-PODge
Date Posted: 23 Jul 2011 at 7:42pm
So axle to ground will remain the same. |
But that still helps in regard to raising the stabiizers so they don't "sand" the pavement on uneven ground, right? My dealer ordered the risers for me and will install them next week. It is costing me a wee fortune, but I can't install them myself, and the menfolk around here are all way too busy for their own good - or should I say for MY own good.
------------- 2011 RP 177, the Hodge-PODge
2011 Mercedes ML350
Date Posted: 23 Jul 2011 at 11:35pm
Welcome, ka9nyn.
Hodge, yes, it raises everything else so you won't scrape your stabs.
Posted By: this_is_nascar
Date Posted: 24 Jul 2011 at 9:05am
But that still helps in regard to raising the stabiizers so they don't "sand" the pavement on uneven ground, right? My dealer ordered the risers for me and will install them next week. It is costing me a wee fortune, but I can't install them myself, and the menfolk around here are all way too busy for their own good - or should I say for MY own good. |
How much is he charging you? If it's more that $100 installation charge, take it somewhere else.
------------- "Ray & Connie"
- 2017 R-Pod RP-180
Date Posted: 24 Jul 2011 at 9:12am
If you order the lifters directly from FR do they come with illustrated install instructions ...or has anyone here ordered/installed them on their own and posted any instructions. I have a floor jack and stands and don't mind taking on projects like that if they are fairly straightforward but with something like that I wouldn't want to just wing it.
Thanks ...
Mark J
Posted By: HuronSailor
Date Posted: 24 Jul 2011 at 9:29am
KA9NYN this is AA8TC. How copy?
------------- .: Mark & Beth :: Silverado 5.3L :: 2018 rPod 180 :.
Date Posted: 24 Jul 2011 at 9:31am
Slogger, yes they come with a single sheet of instructions. And yes some one posted them and a step by step version of their own install experience. I had a local RV shop do mine and he said it went easy. Using my iPad I haven't been able to copy out the links, sorry. Walt
Posted By: FISHTAIL
Date Posted: 24 Jul 2011 at 10:15pm
Thanks ...
Mark J |
Yup. It's easy. See here: http://www.rpod-owners.com/forum_posts.asp?TID=1920&title=axle-riser-diy - http://www.rpod-owners.com/forum_posts.asp?TID=1920&title=axle-riser-diy
