winterize
URL: http://www.rpod-owners.com/forum_posts.asp?TID=3031
Printed Date: 27 May 2024 at 8:08pm Software Version: Web Wiz Forums 9.64 - http://www.webwizforums.com
Topic: winterize
Posted By: OHIOJJ
Subject: winterize
Date Posted: 16 Oct 2012 at 2:33pm
Just winterized. ran sink and shower hot/cold until pink. flushed toilet till pink. put antifreeze down sink/shower drain. pushed so pink came out city water connection. is that it? is 1 gallon enough?
Posted By: techntrek
Date Posted: 16 Oct 2012 at 3:21pm
1 gallon usually does it for me. Did you follow the checklist in the "manual" thread?
Posted By: OHIOJJ
Date Posted: 17 Oct 2012 at 1:27pm
Yes but I'm going to check it again. Thanks.
Posted By: marwayne
Date Posted: 20 Oct 2012 at 1:05am
Make sure to empty the drip pan outside behind the fridge, mine was 1/2 full.
------------- If you want something done right, do it yourself.
Date Posted: 21 Oct 2012 at 8:02pm
A drip pan is news to me, I'll need to go check that.
Posted By: this_is_nascar
Date Posted: 22 Oct 2012 at 4:07pm
Thanks for posting about the pan. I never knew about that. Matter of fact, I don't recall ever taking the cover off to notice it.
------------- "Ray & Connie"
- 2017 R-Pod RP-180
Date Posted: 03 Nov 2012 at 8:32pm
I winterized mine today and remembered to check for the drip cup, sure enough there it was. Only had a half-inch of water in it. I'll add it to the checklist in the "manual".
Posted By: Camper Bob
Date Posted: 04 Nov 2012 at 9:18am
We added an internal water filter at the kitchen sink. After a call to the manufacturer, they suggested taking off the filter itself, putting it into a plastic bag and refrigerating it for the winter. Since there isn't a bypass valve on the filter head, I will have to tie the intake and output together and then do the winterizing. Just thought I would add that to your basic instructions. Safe Travels.
------------- Camper Bob and Camper Sue
2013 Rpod 171HRE(ORPod)
2016 Lance 1685
2015 Nissan Pathfinder
