lug nutts 2016 rpod
Category: Non-pod Discussion Forums
Forum Name: Mods, Maintenance, Tips and Tricks
Forum Discription: Same as podmods, just... not for pods
URL: http://www.rpod-owners.com/forum_posts.asp?TID=8437
Printed Date: 18 May 2024 at 12:47pm Software Version: Web Wiz Forums 9.64 - http://www.webwizforums.com
Topic: lug nutts 2016 rpod
Posted By: guy52
Subject: lug nutts 2016 rpod
Date Posted: 23 Jul 2016 at 8:43pm
If you have a new rpod check your lug nutts to see if they have a metal cover on them i was doing a check on mine before a trip and found four bad ones that just spun !!! I suggest you go to a autozone and replace them you dont want to have to try to change a spare tire and you cant get it off.
Posted By: Leo B
Date Posted: 23 Jul 2016 at 8:53pm
Welcome to the group! Good tip!
------------- Leo & Melissa Bachand
Posted By: StephenH
Date Posted: 24 Jul 2016 at 4:31pm
I had to take a tire off to get a screw removed and the tire patched. I noticed that the lug nuts are not solid, but have the cover. I noticed a crack in one of the covers. In this regard, they are like the ones on my old Ford Escape. I had to replace lug nuts more than once when the cover fell off, exposing a smaller diameter inner nut. At least I had a wrench that would fit so I could get them off.
I probably will replace the lug nuts, but not until I need to. I have other projects that will take priority.
------------- StephenH
