12v outlet - Can I attach to furnace wires?
Category: Non-pod Discussion Forums
Forum Name: Mods, Maintenance, Tips and Tricks
Forum Discription: Same as podmods, just... not for pods
URL: http://www.rpod-owners.com/forum_posts.asp?TID=8645
Printed Date: 18 May 2024 at 11:41pm Software Version: Web Wiz Forums 9.64 - http://www.webwizforums.com
Topic: 12v outlet - Can I attach to furnace wires?
Posted By: Joan and John
Subject: 12v outlet - Can I attach to furnace wires?
Date Posted: 24 Aug 2016 at 2:20pm
In my 176T, I want to install a 12V outlet under the dining seat next to the AC outlet. The furnace is right there, and I am wondering if there are wires that go to the furnace that are always hot that I could tap into? If so, how do I find them?
Posted By: furpod
Date Posted: 24 Aug 2016 at 7:28pm
Yes there are, yes you can. they look like 10g 12v wires, NOT like romex. I have had an outlet back there for years on ours. I used simple squeeze taps to get my power and ground.
Date Posted: 26 Aug 2016 at 1:34pm
Thank you! I tried it. I found the only wires that go to the furnace are 12G. I tapped into them with white on white and red on red. I got some voltage because the fan that I plugged into the outlet had a glowing light (not glowing like usual, but dimly) on the plug, but there wasn't enough voltage to run it.
Then I tried running the furnace and it wouldn't go on even when I unplugged the new outlet. It is 86 degrees here and I set the furnace at 90 and turned on the gas, but no go.
Any ideas?
Posted By: furpod
Date Posted: 26 Aug 2016 at 2:10pm
what is the status of your 12v charge? you should see constant 12v at the heater.
Date Posted: 26 Aug 2016 at 2:23pm
I don't have a tool to measure that. I just noticed that the fuse is burnt out on the furnace.
Posted By: furpod
Date Posted: 26 Aug 2016 at 3:07pm
That can cause a problem..
also, A decent digital multimeter is not expensive, and very handy around the Pod, and the house. It's difficult to trouble shoot electrical stuff without..
Date Posted: 28 Aug 2016 at 7:13pm
Thanks for the help. I found that when I put in a new fuse the furnace worked and so did my outlet.
I am curious as to why there was a little voltage coming through even with the fuse out? Do you know why? it lit up the light on the 12 plug just a little bit, but wouldn't run anything.
(I bought a voltage meter too)
