Campfires - Reflector Fire
Forum Name: Miscellaneous / Off-topic
Forum Discription: Pull a chair up to the campfire and chat. No religious, political or weapons talk, please.
URL: http://www.rpod-owners.com/forum_posts.asp?TID=952
Printed Date: 09 May 2024 at 11:34pm Software Version: Web Wiz Forums 9.64 - http://www.webwizforums.com
Topic: Campfires - Reflector Fire
Posted By: rpodcamper.com
Subject: Campfires - Reflector Fire
Date Posted: 09 Dec 2009 at 10:41pm
A reflector fire is really any fire
that has some sort of flat surface behind it to direct the heat back
out past the fire. This surface is erected behind the fire and pointed,
for example, at the face of a tent, lean-to or other shelter. This back
reflector can be made out of a few large slabs of bark, several logs
laid against supports and stacked upon each other to form the surface.
Rocks can also be used but just like those used to ring a fire, make
sure they do not contain moisture. That trapped moisture can be heated
to where it's like a steam engine with no release valve. Exploding
rocks can send shrapnel and shards flying in every direction!
Posted By: yizit
Date Posted: 09 Dec 2009 at 10:53pm
Would the exploding rocks also apply to landscaping bricks? We use these bricks as a fire ring. Wouldn't want them exploding. Thanks for the info.
Former owner of 2009 172
Darlene & Jim, Ewok our Lhasa
Date Posted: 09 Dec 2009 at 11:18pm
you should be ok with the bricks. My burn pile in the back of my yard is made from cinder block
Posted By: techntrek
Date Posted: 10 Dec 2009 at 8:07am
I've used landscaping bricks (porous off-white variety) for years as a fire ring at home and never had a problem.
Posted By: yizit
Date Posted: 10 Dec 2009 at 3:09pm
That's what I thought. Seems to me they make the bricks by firing them in high tempts. We've never been able to have fires in our own back yard until this year. Lived in the city where it was prohibited.
Date Posted: 10 Dec 2009 at 3:45pm
I lived in the city for 16 years and found that "Campfires" were against the law, BUT "Cooking" Fires was not against the law. So each time we lit a fire in the back yard there was always a pot of water boiling over it. Got to the point that the police stopped coming to check on my fires when they got calls about it. So much better now that we moved out of the city and have the space to burn.
Posted By: yizit
Date Posted: 10 Dec 2009 at 10:41pm
They would allow the stand alone fire pits as long as you were cooking on them too. But it just ain't the same as being in the woods, so we didn't bother with the hassle. No problem anymore tho.
