RPod 171 Select heat on T-stat, but AC starts up |
gpokluda
Senior Member Joined: 11 Nov 2018 Location: NM Online Status: Offline Posts: 337 |
Post Options
Quote Reply
Topic: RPod 171 Select heat on T-stat, but AC starts up Posted: Yesterday at 10:25am |
I remember having this issue when I had my 179. I believe it has to do with the Auto setting. Have you experimented using that setting instead of fan?
Gpokluda
2017 Rpod 179(sold 2023) 2022 Escape 5.0TA 2022 Ford F150 4X4 3.5EB Kawasaki KLR650 |
sjbarry
Newbie Joined: 16 Jun 2015 Online Status: Offline Posts: 1 |
Post Options Quote Reply Posted: Yesterday at 2:03am |
As noted, when I set the thermostat in my 2013 R-Pod 171 to "heat," the heater does not start but the overhead AC does, and it gets cold quickly, the opposite of what I need. Since the original thermostat was showing its age by partially obliterating its display, I switched it out for a new Dometic thermostat, hoping that the replacement would solve the confused HVAC problem. Not to be--the problem persists. The fan setting starts the fan, the cool setting starts the AC, and the heat setting also starts the AC. As far as I can tell, the only HVAC controller is the thermostat itself but what's happening suggests a problem elsewhere, perhaps the wiring? Any insight would be much appreciated.
Edited by sjbarry - Yesterday at 2:04am |
