Introduction - |
Author | ||
CamanoMike
Newbie Joined: 12 Jul 2023 Location: Camano Isl WA Online Status: Offline Posts: 2 |
Topic: Introduction - Posted: 18 Aug 2024 at 6:52pm |
First joined late 2022, but efforts setting up 2020 R-Pod 190 Hood River Edition didn't get far before work project took me away, and included mistakes. I've also been concerned that my plan to tow with Toyota Sienna would not work. Started work in earnest about 3 months ago. All the checking I've done, and review by towing specialist, tell me that the Sienna will work, as long as I'm cautious about weight both in R-Pod and Sienna. The outside kitchen was the first to go, along with a custom platform for a Wen 2250W inverter generator; previous owners had a 4Runner, which has a higher towing capacity. Mistakes previously included using City Water without regulator - that probably ruined the water pump - now replaced. I did keep an oil-heater in one of the storage areas, but something caused problem with toilet water line even with a new water pump. I replaced the toilet with a Thetford Aqua-Magic VI a couple of days ago, and all seems fine now. Why the Sienna you might be wondering. I have two Scottish Deerhounds, and a minivan is wonderful for them. A minivan capable of towing 5,000lbs would be perfect, but that doesn't exist. The current frenzy is for an event early September in part of Washington State that's been extremely hot. I won't go if it doesn't cool down, but indications are that we may be past the worst. I've just tested the generator being able to handle the Dometic A/C - so far, so good. I live North, on Camano Island, which has never reached the temps of the event location. I think my first actual question will be about KIB panels. What a great resource this forum is. And thanks to RpodAdmin for fixing it so I can use the original username.
Mike Edited by CamanoMike - 18 Aug 2024 at 7:08pm |
2020 R-Pod 190,towed by Toyota Sienna
poston
podders Helping podders - pHp Joined: 28 Mar 2018 Location: Nevada Online Status: Offline Posts: 197 |
Post Options Quote Reply Posted: 18 Aug 2024 at 8:02pm | |
Welcome to the group! You probably know you're living on the edge - both in tow vehicle and generator. My 180 has a dry weight of about 2,600 lbs. Outfitted for travel with a little water, propane, and not too much concern with weight, I'm at about 3,500 lbs. Your 2020 190 Hood River is listed at 2,800 dry, which puts you at the recommended 80% of tow capacity (3,500 lbs) before adding water, propane, dishes, food, misc camping gear, etc. Like you said, you need to be very cautious about trailer weight and cargo weight in the van.
I also have the Wen 2250W inverter generator, and I've found it to be the bare minimum to run the a/c. I did have to rejet it for higher elevations, and I put a soft start on it to make it easier to get running. But it does run the a/c! |
-- Jim Virginia City, Nevada 2016 R-pod 180 2015 Nissan Xterra Pro-4X |
gpokluda
Senior Member Joined: 11 Nov 2018 Location: NM Online Status: Offline Posts: 330 |
Post Options Quote Reply Posted: 19 Aug 2024 at 8:26am | |
Welcome CamanoMike. As you already are aware, your rig will be operating at the tip top of its limits. I hope you are using a weight distribution hitch and a good brake controller. Be safe and please share your adventures.
Gpokluda
CamanoMike
Post Options Quote Reply Posted: 19 Aug 2024 at 3:39pm | |
Thanks poston and Gpokluda You probably know you're living on the edge - both in tow vehicle and generator. As you already are aware, your rig will be operating at the tip top of its limits. There's no doubt in my mind that higher 'sanctioned' towing capacity would mean greater confidence. However:
And fingers crossed! |
Senior Member Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3255 |
Post Options Quote Reply Posted: 19 Aug 2024 at 3:52pm | |
Also remember to have at least 11% of the total weight of your loaded 190 on the a-frame (tongue) to reduce/eliminate sway. Hopefully in case of a panic stop you will be able to stop your Sienna/190 in a reasonable/safe distance before having an unfortunate event happen. To be certain of your weights go to your local county garage or similar and have your loaded and ready to camp in 190 and Sienna weighed and find out if you are within safe specs to tow with what you have. Normally it is free to have this done at the county garage. It is one thing to be able to safely tow your 190; it can be a totally different scenario and end event to be able to stop it safely.
Edited by jato - 19 Aug 2024 at 3:53pm |
