Were the 2016's "lifted" from the factory? |
Post Reply | Page 123> |
podders Helping podders - pHp Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6293 |
Topic: Were the 2016's "lifted" from the factory? Posted: 19 Jan 2019 at 9:13pm |
Okay. I misunderstood what you were trying to say. Thanks for clarifying.
GlueGuy
Senior Member Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2631 |
Posted: 19 Jan 2019 at 7:31pm |
I think I was agreeing with you. Sometimes I jump too far ahead or something...
Posted: 19 Jan 2019 at 4:30pm |
Level with lifted vs. not lifted still would be higher with the lifted. That is what I was trying to say.
GlueGuy
Posted: 19 Jan 2019 at 4:21pm |
Posted: 19 Jan 2019 at 2:09pm |
But if the height of the RPod is raised, then it is likely the hitch ball can be set higher also which would mean the hitch would be less likely to drag.
voisj
Posted: 19 Jan 2019 at 1:29pm |
Putting risers on won't help the hitch dragging that height is determined by your hitch ball
Motor7
Senior Member Joined: 09 Jan 2019 Location: E. TN Online Status: Offline Posts: 196 |
Posted: 18 Jan 2019 at 6:16am |
I found this sticker on the axle. Can anyone tell me if it is Lippert or Dexter:
Sorry, the pic resized a little small. The numbers are : V000318009 RPO-045-E13787 I don't get a hit on google with either number.........
Edit: I think I am looking t the wrong sticker. This one is on the end of the axle and the main one should be in the middle.....I'll check again. |
2016 R-Pod 176T
Motor7
Posted: 18 Jan 2019 at 6:07am |
I pulled into that gas station in my pic above about 15 min after buying the Pod....yep drug the hitch and I even went slow and took the driveway at an angle. Right then I suspected I might need risers and your measurement pretty much confirms that.....thanks. GC, I hear ya...but I thought 'everyone' puts leveling bubbles on the hitch plate like me
2016 R-Pod 176T
GlueGuy
Posted: 17 Jan 2019 at 9:25pm |
The measurement that would tell the tail is the distance between the bottom of the frame (or the top of the frame" and the ground in close proximity to the axle. The hitch measurement would only be valid if you are certain the frame is level.
tcj
Senior Member Joined: 05 Jul 2018 Location: Central WA Online Status: Offline Posts: 141 |
Posted: 17 Jan 2019 at 6:24pm |
Blue 180 HRE with 4inch risers between the axel and frame. Came out of the factory in April 2018 but the title says it is a 2019. Axle is clocked at 9 oclock. Bottom of hitch is 20.5 inches. Yes, the frame is level.
2018 R-pod 180 Hood River Edition
