ouR escaPOD mods |
Post Reply | Page <1 3536373839 58> |
Author | ||||
Pod People
Topic: ouR escaPOD mods Posted: 29 Feb 2020 at 8:24am |
INo, I did not use the zamp connector or the alligator clips. I installed a standard 30 amp RV receptacle on the pod's exterior so that I use the 25' standard power cord that came with the pod. Here is a post I made about 4 years ago detailing that installation. There were several comments about the exposed terminals which I have changed. Otherwise, the installation is basically the same as the article. http://www.rpod-owners.com/forum_posts.asp?TID=8194&title=installing-a-renogy-100-watt-suitcase-solar-panel hope this will help you Vann
geewizard
Senior Member Joined: 16 Apr 2017 Location: Spokane Online Status: Offline Posts: 347 |
Post Options Quote Reply Posted: 29 Feb 2020 at 8:27am | |||
I don't use the Zamp connectors but I did make a 50-foot extension cable for my Renogy solar panel. I used Anderson SB50 connectors: and this cable: And these weatherproof boots: I use Anderson SB50 connectors throughout my RPod solar power system and completely avoid the Zamp wiring. I connect my solar panel directly to the solar controller in my battery box on the tongue. |
Post Options Quote Reply Posted: 29 Feb 2020 at 12:01pm | |||
As for using the 30A power cord, I would prefer to leave that heavy thing stowed. I thought of taking a heavy duty 15A extension cord and modifying it. That way, I would only have one cable running between the panels and the RPod. To me, that would make more sense. I'm not sure why two cables, positive and negative, are not run in one jacket for use whith solar panels like this. To me, it would make a lot of sense. As it is, I will be using a lot of zip-ties to fasten the + and - cables together for easier management. I like the Anderson Powerpole connectors and wish I had seen them and the boots earlier. I may order a few for the one set of connectors I would like to make for the A frame connections.
Senior Member Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2631 |
Post Options Quote Reply Posted: 29 Feb 2020 at 1:49pm | |||
Solar systems are wired in a very wide variety of configurations. We have solar sites with anywhere from one panel to 18 panels, all with different series/parallel configurations. The MC4 connectors are "fairly" standard, and they seem to be the ones on most of the panels we get these days. I know that kit comes with a controller that can be configured for lithium batteries. is it by any chance an MPPT controller (I assume not, since it would be a "feature")?
Post Options Quote Reply Posted: 29 Feb 2020 at 5:20pm | |||
It is a Renogy Traveler Series: Voyager 20A Waterproof PWM Controller w/ LCD Display and LED Bar. It supports Lead-acid (Gel, AGM, Flooded, and Calcium) Lithium-ion (LiCoO2, LiMn2O4, LiNiMnCoO2, and LiNiCoAlo2), LiFePO4, and LTO (Li4Ti5O12) batteries. An MPPT controller would have added significant cost to the kit. I figure I can always upgrade later.
Post Options Quote Reply Posted: 01 Mar 2020 at 8:09am | |||
The vast majority of solar modules are used in large arrays and so are connected in series strings building the voltage up to near 600V or higher before parallel connections are made, and those parallel connections are done in a combiner box with fuses. So single conductor connectors are standard practice in the solar world. MC4 connectors became the standard about 10 years ago, and now almost all modules use them or more commonly "compatible" knock-offs from China, some of which are not all that "compatible", resulting in some serious field problems.
For single module 12V battery charging the MC connector approach doesn't offer any advantages. By all means convert over to a two conductor cable (or 3 if you use a grounded extension cord). You could just cut off the MC connectors, solder in butt splices, and heat shrink, but you would probably get an argument if you were ever to make a warranty claim on that module. Be sure to check the gauge of the extension cord if you go that route. A 15A cord is likely to only be 12 gauge or smaller, which is only going to be good for about 25 feet before you lose too much voltage. You'll want at least a 10 gauge cord. Cut off both ends of the extension cord and either connect one end permanently (to the module or battery) or use dedicated connectors at both ends. Don't use the 120Vac connectors for 12Vdc so no one can get confused and connect the wrong stiff together. And don't try to use the MC's to make connections on a daily basis, they're not meant for that and also require a tool to disconnect which would be a PITA. Please do use a properly sized fuse at the battery end to protect that cord and the module. A 10AWG cord should be good for 30A but most modules are rated for 15A so a 15A fuse is a good choice. PWM controllers are fine for a 100 watt 12V module, if you go to one or more 250-350 watt residential/industrial modules those are high voltage so you need an MPPT controller to charge at 12V. Those module are so much cheaper per watt that its worth the extra expense for the MPPT at that point.
Pod People
Post Options Quote Reply Posted: 01 Mar 2020 at 8:55am | |||
I chose to use the existing 25' power cord because I did not want another extension long and heavy cord to carry.It seemed that if we were not hooked to shore power, there was no need for that cord and it would be perfect gauge and length for the solar set up.Use what you have and don't take a lot of extra "stuff" was the idea. As no one except myself or wife will be using or attaching it, I felt there was no issues using 120v cord for 12v application in this case. Granted, for most other, general uses this would not be a good idea. Vann |
Post Options Quote Reply Posted: 01 Mar 2020 at 10:16am | |||
As a professional system designer I of course have to follow the electric code and put safety first. But I've found that the rules are there for good reason, I've seen too many things go wrong. Generally when there are electrical fires its because someone took a shortcut or bent a rule, the argument being that a bad outcome wouldn't happen to them.
Of course for your own use you can do whatever you want, but if you ever sell your trailer I'd suggest that you remove the capability to use that cord on the 12V system.
The tendency to take shortcuts is especially true for 12 or 24 Vdc systems which folks often seem to think aren't dangerous because there isn't a shock hazard risk. One of the things I often see is lack of proper fuse protection on 12Vdc circuits. That I just don't get, there is the same or higher fire hazard risk from faults and shorts as there is in 120Vac circuits. |
Post Options Quote Reply Posted: 01 Mar 2020 at 1:39pm | |||
Remember a spark from a 12v battery gets hot enough to melt metal. So you need to be careful to make sure all your connections are well secured.
Pod People, how are you using your 25' power cord for your 12v dc system? Did you make up some kind of a pigtail to use at the male/female ends of the power cord that you connect to your 12v system? Have you calculated the voltage drop for that cable length and size?
Post Options Quote Reply Posted: 01 Mar 2020 at 1:47pm | |||
