ouR escaPOD mods |
Page <1 3738394041 58> |
geewizard ![]() Senior Member ![]() Joined: 16 Apr 2017 Location: Spokane Online Status: Offline Posts: 347 |
![]() ![]() ![]() ![]() Posted: 03 Mar 2020 at 5:35pm |
I didn't either and that's why I chose to twist my cables together. They roll up and fit within the back frame of the solar panel quite nicely.
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2632 |
There is also a wire sleeve like this. You would have to slip it on before you attached the connectors. The advantage is that it would tightly contain the entire wire run without anything to catch.
I still think just getting a 10 awg extension cord and reterminating it is probably the easiest and least expensive solution. You could even take the internal ground in the cord and tie it in parallel with the negative (white) conductor and reduce the voltage drop further. You'd end up with about a half volt drop at 50 feet with a 100 watt solar module at full sun, which should be fine. No sense in wasting copper
Amazon has a 50 ft Camco 10/3 cord for $57, that's about as cheap as I've seen.
There are two criteria you have to look at when sizing conductors. First is ampacity, which deals with safety, the second is line resistance losses, which deals with efficiency. For 120Vac household circuits you rarely have to worry about line losses, but at 12v it’s a major issue.
So, starting with ampacity, the NEC requirement for solar is to multiply module Isc by 1.56 and select a wire and fuse combination with an ampacity higher than that. Why 1.56? 25% for current enhancement from edge of cloud effects and another 25% to avoid nuisance fuse blows. 1.25x1.25=1.56. Is that conservative? For sure, but being conservative is how the Code keeps us safe. So for ampacity purposes with your module, 6.1x1.56=9.5A so you can use a 10A fuse and a 14 gauge cable. In theory you could even use 16 gauge but the code doesn’t allow for field wiring with conductors smaller than 14. On to voltage drop. General rule of thumb is to keep voltage drop from line resistance to less than 5% or in our case 0.6V. at 12V. You can use one of many free online calculators to find your voltage drop. In this case you can use your Imp of 5.7A as that is normal operating current. At 50 feet you get 0.57V loss with 10AWG. For 12AWG it’s 0.91V which is getting pretty high considering that there are additional voltage losses in the connectors, fuse and fuse block, etc. Nothing stops you from doing it though, it will work and be safe, it’s just not considered best practice. If you parallel the ground conductor with the neutral the loss with 12 would be 3/4 of 0.91=.68V which you might just call good enough in the interest of keeping cost and weight down. Back on the fuse, since 10AWG is good for 30A you can use a fuse rated higher than 10A, the upper limit is probably 15A as that is typically the fuse rating of most solar modules. Hope this long explanation makes sense. |
Thank you. The alligator clips are fused with a 10A fuse from Renogy. Given that it looks like a smaller gauge wire is used for that harness, I expect that it is appropriate. Thanks for the details. I understand where 10AWG is best now. I definitely would not use 14AWG or 16AWG, both of which I have seen listed for sale. I might opt for 12AWG as I could get a 50' length of two conductor 12AWG wire from one source, but in reality, it would not be at any savings over the 10AWG pre-made extension cord. I'm going to punt this down the road for now since I did get the 25' extension wires. I'm not sure I will need more for now.
If you can find an inexpensive source for two conductor SO cord that would be ideal, fine stranding so very flexible with nice thick insulation. But an extension cord is generally going to be cheaper.
