Help Choosing a Tow Vehicle |
Post Reply | Page <1234> |
Pod_Geek
Senior Member Joined: 04 Dec 2019 Location: Colorado Online Status: Offline Posts: 260 |
Topic: Help Choosing a Tow Vehicle Posted: 28 Oct 2020 at 9:12am |
Here's a (possibly) helpful link:
https://news.pickuptrucks.com/2019/10/breaking-down-the-2020-toyota-tacomas-towing-capacities.html
2020.5 R-Pod 195 Hood River
2018 RAM 2500 6.4L |
Posted: 28 Oct 2020 at 9:46am |
For me the reason for choosing a full size pickup over a mid sized one would be to have the additional safety margin in weight handling capacity, particularly if you are going to boon dock and carry water and lots of gear in the tow vehicle.
The fuel economy of a full size pickup vs a mid size is not really significant when not towing and nonexistant towing. For example the 3.5L 4wd Taco is rated 18 city/22 highway vs the F150 4wd 3.5L at 16/22. Either is going to provide around 13-14 mpg towing on flat ground in the 60-65 mph range. Beyond that its what you're comfortable with driving around not towing. You might want to consider an SUV rather than a pickup as well. Depends what other uses you plan on for the vehicle and how many passengers you have. Personally I need two row seating and find the double cab pickups with a "vestigial" 5 to 5.5 foot bed pretty useless as work vehicles, and the full size bed double cab trucks too long to maneuver. So not being able to afford dedicated vehicles, I use an SUV and a utility trailer for work and the SUV and rpod for travel. Test drive a few vehicles with tow ratings of 6500 lbs or more and 4wd then decide. |
Pod_Geek
Posted: 28 Oct 2020 at 10:01am |
I found it interesting that in the link I posted that 2WD Tacomas have a higher tow rating than 4WD. Is that due to the added weight associated with 4WD vehicles?
Posted: 28 Oct 2020 at 10:34am |
Yep, if you look at the Toyota website the 4wd weighs 240lbs more than the 2wd with the same trim. The GVWR and MCVWR are identical. The payload on the 4wd is 240 lbs less. The towing capacity difference is rounded up to 300 lbs.
I'm with CharlieM though re 4wd for towing, there have been many many times I've been glad to have it, not just in inclement weather but on soft surface roads with steeper grades, and even pulling a trailer up a slight slope on wet grass.
Posted: 28 Oct 2020 at 10:58am |
The same exists for the Frontier. It likely is the additional weight and drag of the 4WD gearing.
Capt Kidd
podders Helping podders - pHp Joined: 18 Aug 2015 Location: Chico, CA Online Status: Offline Posts: 212 |
Posted: 28 Oct 2020 at 12:32pm |
I tow my 196 with a Dodge Durando V-6. No WHD hitch or sway bars and it tows just fine. I get 12 to 14 mpg at 60 mph. The Durango has paddle shifters and I use them and mostly tow in 7th gear if there us no head wind.
The Pirate's Pod
Capt Kidd
Posted: 28 Oct 2020 at 12:34pm |
My Durango is a 2016 with all wheel drive. It is rated to tow up to 6200 lbs.
The Pirate's Pod
podwerkz
Posted: 28 Oct 2020 at 12:45pm |
You did not mention a budget (or shopping used) so I assume you are looking at brand new trucks? I'm not a Toyota fan so I will steer you towards the mid-sized Nissan Frontier or Ford Ranger. |
Pod_Geek
Posted: 28 Oct 2020 at 12:54pm |
I think it might be important to indicate the conditions/areas that one tows in. Nebraska <> SW Colorado.
Gypsiejanie
Newbie Joined: 24 Oct 2020 Location: New Mexico Online Status: Offline Posts: 16 |
Posted: 29 Oct 2020 at 8:31am |
Thank you for your response. It's just me and my little dog. However, I will be moving out of my house and toting some bins with me in the tow vehicle...travel camping on my way to relocating on the other side of the US. The tow vehicle will be my only vehicle, so it's got to be. good and reliable one. At this point I'm thinking full size SUV or full size truck but the sticker shock difference is...well, OUCH! So I'll have to buy used. Lots of research to do.
