180 black tank issues |
Post Reply | Page <12 |
Topic: 180 black tank issues Posted: 19 May 2021 at 6:09am |
One thing that significantly reduces overall "grossness" is to use the campground bathrooms as much as possible. We reserve our rpod toilet use to numbah 1 at night only when in established campgrounds. Boondocking of course is another story.
Posted: 18 May 2021 at 7:13pm |
Yeah, that is gross. 1st through 21st thoughts. More than that, it's unnecessary. Plenty of water is the answer. Have a few gallons in the black tank to start, flush the toilet with plenty of water, top of the tank before emptying it. Why in the world have a plumbing system you don't use? Problems can happen, but rarely with plenty of water. Deal with the problems when they come up but enjoy having the fully-functional bathroom you paid for! TT
FJ Cruiser |
Posted: 18 May 2021 at 8:29am |
In addition to using a really good digester/enzyme agent to dissolve the solid waste, another thing you can do to ensure better black tank emptying is to avoid putting paper products into the tank. Though at first thought, it's gross, it makes emptying the tank easier. We've been doing it for since we got our 172 and have never had a problem fully emptying the black tank. Our method is similar to that seen in countries where plumbing systems are limited. Simply discretely fold the soiled paper and put it into a small plastic bag to be thrown away in the trash like a dirty disposable diaper.
Cali82
Newbie Joined: 15 Mar 2021 Online Status: Offline Posts: 4 |
Posted: 17 May 2021 at 9:11pm |
Thank you gentlemen... off to check my drainage layout and explore Tom’s valve suggestion!
podders Helping podders - pHp Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6294 |
Posted: 17 May 2021 at 8:45pm |
The hydroflush works best if there is a straight pipe into the tank. On ours, it takes a turn at the tank before heading out. I don't see it as being very effective in the case of my tank's drainage layout.
SC for Huskers
Senior Member Joined: 22 Feb 2017 Location: Goose Creek, SC Online Status: Offline Posts: 144 |
Posted: 17 May 2021 at 8:35pm |
I use something like this that I got from Etrailer.com Valterra Hydroflush Reverse Flush Adapter for RV Holding Tanks. Item # F02-4100 |
Happy Traveling,
Tom 2017 172pod 2011 F150 STX |
Cali82
Posted: 17 May 2021 at 8:06pm |
It does, but not getting enough pressure from the city line to completely flush it that way without the additional stick/hose flush through the actual toilet. Thank you for the tips! I will look into better chemicals and TankTechs.
Posted: 17 May 2021 at 7:35pm |
Does your RPod not have a black tank flush?
Use a good biological agent such as TankTechs Rx or RV Digest-It to help liquify the solids. Use plenty of water when flushing #2. Don't empty the tank until it is at least 2/3 full. Given that the tank sensors are notoriously unreliable, you will need to estimate when the tank is full enough to dump. While you are at it, look up TankTechs and view the various videos there. It will be quite informative and will likely be very helpful.
Cali82
Posted: 17 May 2021 at 7:29pm |
Hi folks,
New full timer here, so please be nice! Not yet traveling so no bumps to jiggle things loose in the black tank. I’ve tried the little pods you drop in, I’m using RV toilet paper (and being careful of consumption), I’m leaving some water in the black tank after flushing. I’m still getting solid back up and having to flush with stick attachment to the hose in the toilet every time I empty. Any suggestions to help a newbie out?! |
