Replacing kitchen faucet |
RebaBarker
Newbie Joined: 26 Sep 2023 Online Status: Offline Posts: 1 |
Topic: Replacing kitchen faucet Posted: 05 Oct 2023 at 3:53am |
Replacing a kitchen faucet is a DIY project that can refresh your kitchen's look and functionality. It typically involves disconnecting the old faucet, installing the new one, and ensuring proper sealing, with costs varying based on faucet type and brand, ranging from $100 to $500 or more.
gpokluda
Senior Member Joined: 11 Nov 2018 Location: NM Online Status: Online Posts: 278 |
Post Options Quote Reply Posted: 19 Nov 2022 at 10:47am |
I replaced the faucet in my 179 a few weeks ago. Knowing we will be selling the Rpod soon, I went with another two handle faucet with a pull-down sprayer. This required a 1 1/2" hole between the hot and cold centers. By taking out the two drawers below the sink, I was able to remove and install without having to remove the sink. Total time was less than 30 minutes.
Gpokluda
2017 Rpod 179(sold 2023) 2022 Escape 5.0TA 2022 Ford F150 4X4 3.5EB Triumph T120 |
Jefferson
Newbie Joined: 29 Apr 2021 Location: NorCal Online Status: Offline Posts: 18 |
Post Options Quote Reply Posted: 05 Nov 2022 at 10:49pm |
Thanks! Exactly - the original has a limited shelf life :)
Post Options Quote Reply Posted: 05 Nov 2022 at 10:31pm |
Nice job. When I did this on a 2011 177 a number of years ago I also had to purchase a couple sharkbite adapters to make the hot and cold connections. You will be pleased with the new faucet; no more squeaks and groans when you turn water on and off.
Jefferson
Post Options Quote Reply Posted: 05 Nov 2022 at 9:04pm |
Recently inspired to replace the leaky, original kitchen faucet in my 2015 Rpod 177 after reading the many posts on the subject. Could not have done it as easily without removing the sink as other suggested previously by removing the 4 wing nuts under the counter (see photo) and the plastic ring that connects the sink + drain to the P-trap. Did not need to change out any of the PEX fittings - the 1 inch white plastic threaded female fittings fit onto the copper threaded male fittings for hot (red) + cold (blue) on the new Moen faucet - see photo with the sink removed. Teflon tape on the connections. Pressure tested, no leaks. Now, just waiting for some non-petroleum plumbers putty to use on the plastic sink + drain before reinstalling. If I can do this, anyone can...just thought I'd share as a 'thank you' for all the tips + info this community generously provides. Tempted to put in a new sink, but good for now :) |
