Page 123> |
osage ![]() Senior Member ![]() Joined: 13 Mar 2016 Online Status: Offline Posts: 146 |
![]() Posted: 14 Jun 2016 at 6:34pm |
95 in the shade here in eastern Kansas today Fridge set on 5 temp in fridge is running at 50.
fridge coil fans not running is there any way to check the cooling coil thermal switch. |
Tars Tarkas ![]() Senior Member ![]() ![]() Joined: 14 Jan 2013 Location: Near Nashville Online Status: Offline Posts: 1446 |
What kind of power is the fridge on? Needs to be shore power or propane.
TT |
FJ Cruiser |
fridge is on 110 volts
IIRC my RPOD fridge would only maintain 40 degrees F below outside ambient. Looks like you're 5 degrees to the good.
Leo B ![]() podders Helping podders - pHp ![]() Joined: 13 Jan 2012 Location: Lyndonville, VT Online Status: Offline Posts: 4512 |
+1 I agree
but shouldn't the cooling fans come on
JandL ![]() Senior Member ![]() ![]() Joined: 29 Mar 2014 Location: California Online Status: Offline Posts: 364 |
Here is a schematic of the Dometric RM-8501 showing the 2 fans. They are controlled by a thermal switch mounted on the condenser coil.
sch_rm_8501.pdf |
JandL
2013 Honda Ridgeline 2012 177 2 Paynes in a Pod |
techntrek ![]() Admin Group - pHp ![]() ![]() Joined: 29 Jul 2009 Location: MD Online Status: Offline Posts: 9059 |
Mine stayed in the upper 30's even in hot temps. Same for my current fridge.
got the fridge to cool ok now had to move the thermal switch to the right hand side of the cooling coils now the fans come on cools the the mid 30 to40 degree area was 96 here friday
johnmaci ![]() Senior Member ![]() ![]() Joined: 17 Jun 2014 Location: MD Online Status: Offline Posts: 202 |
Was this accessible from the outside or did you have to pull out the fridge? Any before/after pictures?
Page 123> |
