  New Posts New Posts RSS Feed: Dometic RM8501 refrigerator, my fix when on gas
Topic ClosedDometic RM8501 refrigerator, my fix when on gas
DavMar View Drop Down
Direct Link To This Post Topic: Dometic RM8501 refrigerator, my fix when on gas
    Posted: 11 Sep 2017 at 10:38am
Originally posted by geewizard
There's a 12v connection for the fridge at the bottom.  I wired the fans in there with a switch so I can turn them on or off.
Great idea! Do you just switch them on when the outside is at a certain temp?
wonder dog.
2017 Rpod 180
2016 Toyota Tacoma SR5 4x4
Lexington, NC
AndR View Drop Down
Direct Link To This Post Posted: 11 Sep 2017 at 9:33am
Thanks
Thanks and Happy Camping!
geewizard View Drop Down
Direct Link To This Post Posted: 11 Sep 2017 at 9:13am
2004 Outfitter Apex 8 camper
2014 Toyota Tundra DC
AndR View Drop Down
Direct Link To This Post Posted: 10 Sep 2017 at 10:12pm
Thanks for the info. My fridge has worked well for the last five years at this location and higher elevations. This is a new problem that has me scratching my head.
JandL View Drop Down
Direct Link To This Post Posted: 10 Sep 2017 at 9:51pm
All gas appliances have reduced efficiency at high altitude, at sea level air is 20.9% oxygen and at 6000 feet 16.6%. Was your refrigerator compartment full? I live at 25 feet so it does not compare to where you are at. When I was doing my test I had to put items in the main compartment so they would absorb the cold. If it’s empty only the air is cooled and the minute you open the door the temperature will drop. When I did my test I put bowls of water on the shelves and filled the door shelves with sodas. I put a bag of flour in the vegetable storage bin. Even then when I opened the door I would lose 1-2 degrees. In the freezer I put blue ice bags and a ½ pint of water to see how well it would freeze. I'll have to check mine the next time I am at 6000 feet. I have a remote temp sensor I keep in the refrigerator now, that way I can see how cold it is inside without opening the door
JandL
2013 Honda Ridgeline
2012 177
2 Paynes in a Pod
AndR View Drop Down
Direct Link To This Post Posted: 10 Sep 2017 at 8:55pm
Propane run time 12 hours. This was after the fridge had been at proper temp on AC.  Outside air temp,was 80f. Elevation is 6000. Did not check actual temp in freezer but water was frozen, refer comp was 52f
Direct Link To This Post Posted: 10 Sep 2017 at 3:01pm
How long has it been running on propane and what are your temperatures for the main compartment and freezer, outside air temp, and elevation
JandL
2012 177
2 Paynes in a Pod
AndR View Drop Down
Direct Link To This Post Posted: 10 Sep 2017 at 2:07pm
OK, I have:
Checked door seal- good
Thermoster-good
Trailer is level
Propane tank is full
Cleaned the flue
Cleaned the burner assembly
Have a good flame.
I still cannot get the refer part to get cold when using propane. The freezer works though.
The whole unit works on AC and battery.
Any suggestion?
AndR View Drop Down
Direct Link To This Post Posted: 07 Sep 2017 at 10:54pm
Thanks for the reply. I did drive a long a bumpy road for about 80 miles. Has not seemed to make a difference. I will check the seal and then readdress the burner issue.
Thanks!
Direct Link To This Post Posted: 07 Sep 2017 at 9:38pm
I have read on the internet about turning the refrigerator over, I have also read just as many post saying driving on a long bumpy twisty road will work just as well. From my testing if your freezer is getting to the correct temperature but the main compartment is too warm I would check your door gasket. I had the opposite problem the main compartment was cold but the freezer was warm. It turned out to be a cracked hinge.
Freezer door hinge repair
Absorption refrigerator cool off very slowly and even a small air leak can be a big problem. When I was trying to measure the temp in the freezer and main compartment I had to open and close the doors quickly. This is the reason you turn your refrigerator on 24 hours before leaving because it cools down so slowly. Did you put a thermometer in your freezer compartment to see if it was getting cold enough? If everything is working great on AC but you are having issue with propane them yours may be like mine and the flame may not getting hot enough for the absorption cycle to work correctly. I saw a much better looking flame after I replaced the tank regulator and cleaned the burner assembly. Another item I discovered is my model of refrigerator has an inline ceramic filter located on the gas control valve. I have sent an email to Dometic asking about it. (Dometic Refrigerator Gas Valve Adapter Filter 2923191007)
JandL
2012 177
2 Paynes in a Pod
