  New Posts New Posts RSS Feed: 4Runner trailer connection Mod
Topic Closed4Runner trailer connection Mod
mcarter View Drop Down
Direct Link To This Post Topic: 4Runner trailer connection Mod
    Posted: 24 Sep 2018 at 4:16pm
Tony,
There is a couple on this forum having same issues, looking for assist. I think member name is Laurazalla. SHe is posting with a 4 runner issue. Can you help?
Direct Link To This Post Posted: 23 Sep 2018 at 6:58pm
Good job, makes sense Tony.
tony rpod 180 View Drop Down
Direct Link To This Post Posted: 23 Sep 2018 at 6:47pm
The factory trailer connection receptacle and bracket on the Toyota 4Runners makes no sense.  It is located under the rear cargo compartment.
I was tired of laying on the ground to plug in my trailer connector and also it kept coming disconnected while I was towing so I installed this bracket on my 2018 4Runner. You can use the factory mounting holes where the original bracket was installed. I also added two 1” spacers to locate the bracket below the bumper, there is just enough harness length also(had to remove clip from frame rail) I also drilled a new hole in the bracket so it would be parallel to the bumper. I ordered the bracket from etrailer.com for about $8-9
< ="" style="margin-bottom: 6px; font-size: 11px;">Attached Thumbnails
Click image for larger version    Name: AAFFB6B7-E6BE-4691-BD99-749FE4FA90B5.jpg  Views: 23  Size: 191.0 KB  ID: 187165   Click image for larger version    Name: 6F58C0AA-828B-468A-9E59-4F07BA81378D.jpg  Views: 29  Size: 164.0 KB  ID: 187166   Click image for larger version    Name: 4DD8C458-CAD9-479B-9F51-B432D162CC91.jpg  Views: 22  Size: 136.9 KB  ID: 187167   Click image for larger version    Name: 3CE96AE3-D6FE-42AD-920F-6448F22D527E.jpg  Views: 21  Size: 167.0 KB  ID: 187168
GMC Canyon/RPoder
