Were the 2016's "lifted" from the factory? |
Post Reply | Page <123> |
Topic: Were the 2016's "lifted" from the factory? Posted: 17 Jan 2019 at 5:34pm |
If it were lifted up to take the load off, the clocking of the arms would probably be about 8:00 if it is 9:00 under load. It sounds like you have the re-clocked axle. I would measure mine, but my driveway is not level so any measurement I take would be inaccurate.
tcj
Senior Member Joined: 05 Jul 2018 Location: Central WA Online Status: Offline Posts: 141 |
Posted: 17 Jan 2019 at 6:20pm |
darnit, hit the wrong button.
2018 R-pod 180 Hood River Edition
tcj
Posted: 17 Jan 2019 at 6:24pm |
Blue 180 HRE with 4inch risers between the axel and frame. Came out of the factory in April 2018 but the title says it is a 2019. Axle is clocked at 9 oclock. Bottom of hitch is 20.5 inches. Yes, the frame is level.
Posted: 17 Jan 2019 at 9:25pm |
The measurement that would tell the tail is the distance between the bottom of the frame (or the top of the frame" and the ground in close proximity to the axle. The hitch measurement would only be valid if you are certain the frame is level.
Motor7
Senior Member Joined: 09 Jan 2019 Location: E. TN Online Status: Offline Posts: 196 |
Posted: 18 Jan 2019 at 6:07am |
I pulled into that gas station in my pic above about 15 min after buying the Pod....yep drug the hitch and I even went slow and took the driveway at an angle. Right then I suspected I might need risers and your measurement pretty much confirms that.....thanks. GC, I hear ya...but I thought 'everyone' puts leveling bubbles on the hitch plate like me
2016 R-Pod 176T
Motor7
Posted: 18 Jan 2019 at 6:16am |
I found this sticker on the axle. Can anyone tell me if it is Lippert or Dexter:
Sorry, the pic resized a little small. The numbers are : V000318009 RPO-045-E13787 I don't get a hit on google with either number.........
Edit: I think I am looking t the wrong sticker. This one is on the end of the axle and the main one should be in the middle.....I'll check again. |
2016 R-Pod 176T
voisj
Senior Member Joined: 19 Jul 2016 Location: San Luis Obispo Online Status: Offline Posts: 471 |
Posted: 19 Jan 2019 at 1:29pm |
Putting risers on won't help the hitch dragging that height is determined by your hitch ball
Posted: 19 Jan 2019 at 2:09pm |
But if the height of the RPod is raised, then it is likely the hitch ball can be set higher also which would mean the hitch would be less likely to drag.
Posted: 19 Jan 2019 at 4:21pm |
Posted: 19 Jan 2019 at 4:30pm |
Level with lifted vs. not lifted still would be higher with the lifted. That is what I was trying to say.
