  New Posts New Posts RSS Feed: battery not charging
Topic Closedbattery not charging
sean p View Drop Down
Direct Link To This Post Topic: battery not charging
    Posted: 13 Aug 2019 at 4:35pm
So my battery is not recieving a charge for shore power or my TV.. Is this a converter issue. I changed the terminal conections today and still showes nopower to battery. according tothe idiot lights in the camper. And when i use the fan its dogging, When i plug into shore power it shows full charge and every thing runs fine..Any help would be nice, Thanks Sean
2016 179pod--BETTY
2010 nissan frontier
Sean and Doug
Butchie the morkie
touring the west
Direct Link To This Post Posted: 13 Aug 2019 at 4:53pm
The charger isn't used when charging from your TV, so if you're having problems with both power sources perhaps its not the sources at all, it could be your battery that isn't holding a charge.  If it hasn't been replaced since the trailer was new in 2015/16 that is quite likely. Do you have a multimeter you could troubleshoot this with?
Direct Link To This Post Posted: 13 Aug 2019 at 5:25pm
What fan? The converter fan?
Direct Link To This Post Posted: 13 Aug 2019 at 7:10pm
If it runs on shore power, that would mean the converter is providing 12V. It may just be a bad battery, or a loose connection to the battery/ies.
Direct Link To This Post Posted: 14 Aug 2019 at 7:24am
If everything is fine when plugged in, your converter is fine.
If your battery isn't taking a charge, it's the battery or it's wiring.
Olddawgsrule View Drop Down
Direct Link To This Post Posted: 14 Aug 2019 at 8:42am
If I'm reading this correctly, sounds like you are getting charge to the battery, and the battery is not excepting.
I agree fully with Offgrid, get out your multimeter and start trouble-shooting.
With Shore/TV unhooked, take a reading off the battery and record this number. Then hookup shore and record this number. Please report back with findings.
Byways no Highways
2017 Tacoma
Truck Camper Build
2004 F150 My Overlander
Direct Link To This Post Posted: 14 Aug 2019 at 9:20am
Thanks everybody, it was the battery, New one in place now..
2016 179pod--BETTY
Sean and Doug
Butchie the morkie
touring the west
Direct Link To This Post Posted: 14 Aug 2019 at 11:01am
Keep an eye on it. Here's a good chart to work from.
As a simple rule, 12v's not below 75%, 6v's not below 50%
Gel's and AGM's can be pushed a bit deeper, yet as. standard/simple rule, it works well.
Byways no Highways
2017 Tacoma
Truck Camper Build
