  New Posts New Posts RSS Feed: holding tank level indicator lights
jdreed@frontier.com View Drop Down
Post Options Post Options   Quote jdreed@frontier.com Quote  Post ReplyReply Direct Link To This Post Topic: holding tank level indicator lights
    Posted: 21 Sep 2019 at 4:27pm
(1) Can the holding tanks indicator lights be adjusted to more accurately show how much is in the respective tanks? My 2018 R179 will show 1/3 full with the almost the first first gal., of liquid then remain on 1/3 after draining the tank.
John P Reed, Sr
Post Options Post Options   Quote mcarter Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2019 at 5:03pm
Not to my knowledge, they are historically inaccurate, and should only be used as an estimate.
Tars Tarkas View Drop Down
Post Options Post Options   Quote Tars Tarkas Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2019 at 5:16pm
Essentially, they don't work so you should learn how deal with tank levels without them.  It's not hard.  The potable tank holds 30 gallons as do the grey and black tanks, so you can't fill them without coming up with more potable water.  This assumes you have no hookups.  If you have a water hookup but not sewer you can get in trouble.  Worst case, you'll see the level of the black tank when you hold the toilet valve open and the grey tank will start backing up into the shower.
The sensors for the lights get coated with junk.  Sometimes you can clean them for a moment, but you can never know when they quit again.
Post Options Post Options   Quote furpod Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2019 at 5:51pm
Hokum. HOKUM I SAY!
Really they are useless.
Signature removed, so as not to trigger any non Ford owners, non Irish Setter owners, current R-Pod owners, unhandy or mod negative Pod owners, or single campers of any gender.
podwerkz View Drop Down
Post Options Post Options   Quote podwerkz Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2019 at 7:24pm
But they look pretty....
Wink
r´Żąpod 171
Post Options Post Options   Quote offgrid Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2019 at 7:56pm
Wink
Heh heh
2012 Toyota Highlander
CharlieM View Drop Down
Post Options Post Options   Quote CharlieM Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2019 at 2:56pm
The LED sensor lights, including the battery indicator, are essentially worthless but they may be good for mood lighting LOL
