Add Inverter? |
Post Reply | Page 12> |
Colt
Topic: Add Inverter? Posted: 22 Nov 2019 at 8:27pm |
Is there an elegant way to add an inverter to my 180 so I can watch the TV and charge a phone from the 120V outlets off battery power? Maybe a converter that becomes an inverter when off shore power?
John
'16 R-Pod 180 |
Olddawgsrule
Posted: 23 Nov 2019 at 7:15am |
Elegance is in the eye of the beholder. I mounted mine under the dinette since that's where I worked. The inverter ran the second monitor and re-charged the laptop. That's it.. Personally, I have found the tv not to be useful at all. Barely gets any stations and don't like size nor location of mount, I took mine out. I use my laptop for movies and such.
Posted: 23 Nov 2019 at 9:32am |
Posted: 23 Nov 2019 at 11:12am |
We installed one of these for our Pod and it really worked well for charging phones and such, and to run a small cigaret lighter plug in inverter to charge a laptop: https://www.amazon.com/gp/product/B07P5MZ111/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
I just got an new one to put in the Sonoma.
Olddawgsrule
Posted: 23 Nov 2019 at 12:37pm |
I'll vote for elegance! |
Posted: 24 Nov 2019 at 12:36am |
+2 on the 12V tv and USB ports.
Much more elegant than an inverter and more efficient. Get a dual voltage TV, they’re not expensive. By the time you recover a few bucks on Craigslist for the old TV I think you’re ahead cost wise vs an inverter. As for watching stuff, get an Hdmi adapter for your smart device and you can either stream or play recorded video to the tv, while using Bluetooth to connect to the trailer audio system. |
Colt
Posted: 24 Nov 2019 at 4:37pm |
I have cables for connecting phone or tablet and laptop to HDMI and audio from TV to "stereo" (and I thought Blose was bad...). I did not know I could buy 110/12V TVs, but Amazon is rife with them. Anybody know what the load limit on the TV mount is?
John
'16 R-Pod 180 |
Posted: 24 Nov 2019 at 7:02pm |
The mounts usually state the load they will hold. Your bigger problem is how much weight will the point of attachment to the trailer hold. If you don't get a structural member as backing, you may want to add a base plate attached to structural parts.
Colt
Posted: 25 Nov 2019 at 12:25pm |
So, there is 12v behind the fuse box, under the dinette? |
John
'16 R-Pod 180 |
Colt
Posted: 25 Nov 2019 at 12:29pm |
Exactly. I have the OEM TV and mount. I have seen in some places the framing is wood and is aluminum in others. What is used for "studs" in the walls? I want to mount a mirror over the bathroom sink, too. |
John
'16 R-Pod 180 |
