New "hard" propane tank cover? |
Post Reply | Page <12 |
Senior Member Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3220 |
Topic: New "hard" propane tank cover? Posted: 05 Feb 2023 at 4:24pm |
I have a plastic cover for two 20# tanks and experienced the same issue. Simply remount the regulator and go to your local propane distributor and have them make a longer pigtail for you. Measure first and add a few inches for comfort.
hank*pod
Groupie Joined: 06 Oct 2022 Location: PA Online Status: Offline Posts: 61 |
Post Options Quote Reply Posted: 05 Feb 2023 at 7:03pm |
Post Options Quote Reply Posted: 05 Feb 2023 at 8:07pm |
Most likely yes it can be, however in my case the pigtail had to be rerouted and replaced with a longer one to make it functional.
J.G.S.
Newbie Joined: 14 Dec 2022 Location: Bastrop Texas Online Status: Offline Posts: 3 |
Post Options Quote Reply Posted: 07 Feb 2023 at 4:16pm |
I have a single cover that I took off my 179 , I installed a second tank and now have a dual hard cover. It's yours if you want it.
J.G.S.
Post Options Quote Reply Posted: 07 Feb 2023 at 5:35pm |
I have both single and double. The double is on the RPod. The single is being used on my deck.
gpokluda
Senior Member Joined: 11 Nov 2018 Location: NM Online Status: Offline Posts: 275 |
Post Options Quote Reply Posted: 07 Feb 2023 at 7:25pm |
Like StephenH's recommendation, I installed a zip tie at each hinge joint to provide a tether in the event the wind tries to suck the lid off. Worked fine for many, many miles. The zip ties will get brittle after some time so make sure to replace them occasionally.
Gpokluda
2017 Rpod 179(sold 2023) 2022 Escape 5.0TA 2022 Ford F150 4X4 3.5EB Triumph T120 |
