  New Posts New Posts RSS Feed: Axle Problem 2015 182G
Topic ClosedAxle Problem 2015 182G
Direct Link To This Post Topic: Axle Problem 2015 182G
    Posted: 06 May 2021 at 12:48pm
I'm looking forward to hearing how it goes and seeing some pictures.
Direct Link To This Post Posted: 07 May 2021 at 6:57am
There isn't really anything upscale in quality in an rpod. If you want a high quality trailer get something like a Bigfoot. Tons more money and weight.
Weight is a key criterion in the design of the rpods. FR sells these things to folks with little 3500 lb tow rated SUVs (now there is a bad business practice for you, and dangerous). They can't keep the weight and cost low without giving up something, which is strength in this case.
I ordered my ubolts. They weren't available at hardware stores. The link is in my write up, good folks to deal with. Be sure to get your dad to camber the angle to mate up with the recambered axle. The proper crown dimension is discussed in the write up, run a string line along the bottom of the axle end to end and measure the gap in the center, with load off the wheels.
Direct Link To This Post Posted: 07 May 2021 at 2:48pm
Light-cheap-strong.. pick two.
SC for Huskers View Drop Down
Direct Link To This Post Posted: 07 May 2021 at 3:59pm
Offgrid, Do you think the 5" U bolts would be long enough, or do you think go like you did with the 6" and cut them off.Confused   Another one please, did you use lock washers or the flat ones that come with the bolt as a kit?
Thanks
Happy Traveling,
Tom
2017 172pod
2011 F150 STX
Direct Link To This Post Posted: 07 May 2021 at 4:23pm
The longer ubolts were helpful because it made it easier to get the nuts started. The angle being slightly bent doesn't initially push up tightly against the axle with the first ubolts. It all comes together fine once you get all the ubolts on and start tightening them. I think if you used a floor jack in the center shorter ones would be ok, I was holding the angle up by hand which made it a bit awkward. No need to cut them off if you use the long ones, they're not in the way of anything. You need a long reach socket though.
The ubolts I got were fine threaded with heavy washers behind the backing plate. They didn't use or need lock washers. There was a specific torque setting for them IIRC.
Olddawgsrule View Drop Down
Direct Link To This Post Posted: 07 May 2021 at 4:34pm
LOL Ain't that the truth..
Byways no Highways
2017 Tacoma
Truck Camper Build
2004 F150 My Overlander
Direct Link To This Post Posted: 07 May 2021 at 5:52pm
Is there one that's cheap and strong?
Blitzkrieg3002 View Drop Down
Direct Link To This Post Posted: 07 May 2021 at 7:03pm
So, just got done temp fixing the pod. Turns out the axle is okay. We’ll sort of. The problem was a bent spindle. We started off by hooking a dial indicator up and measured about 50 thousands of flex in the edge of the axle jacking up the pod and lowering it back down. Nothing too crazy to us. We then pulled the tire off and could clearly see the bent spindle.
We grabbed an old leftover bent wheel, a BFH, a straight edge to check our bend and progress, some jack stands to brace properly and went to town correcting the bend.
I didn’t get a ton of pics but here’s what I got.
Before
Putting some force on the wheel
BFH time
After
I had to replace the brake shoes as well. The drum was so cockeyed it wore the rear brake shoe down to metal. I’ll likely order a new axle, but being so long out with shipping. (Quotes over a month wait) I’m happy with fix for the time being.
I really don’t know what I must’ve hit to cause this. Truly puzzling. the amount of force required, one would think I would’ve noticed. Guess it’s just these California roads.
Direct Link To This Post Posted: 08 May 2021 at 6:07am
Very interesting and thanks for the report and the temp fix. I'd worry about putting a lot of side load on the frame with the bottle jack though.
I was wondering when we'd get a bent spindle here. When you said your axle hadn't lost it's crown that was a good clue. Unfortunately you can't replace a spindle, they assemble them by compressing and freezing the rubber, insert the spindle, and let it thaw. No way to reverse that.
In the end a 3500 lb axle is just too light for a heavily loaded rpod on the kind of roads we have in a lot of the country. If you're having to replace brake assemblies as well as the axle it wouldn't be much more $ to upgrade to the heavier axle.
Direct Link To This Post Posted: 08 May 2021 at 6:26am
Blitz, good thing you didn't tow your Pod across Indiana on I-80.  The bend in the spindles would likely have left your tires touching the trailer on the top side.  Ouch
