  New Posts New Posts RSS Feed: Mystery door leak
Topic ClosedMystery door leak
Goose View Drop Down
Direct Link To This Post Topic: Mystery door leak
    Posted: 08 Oct 2012 at 11:03pm
   I noticed this morning a small bit of light coming in between the door frame and the wall at the floor on the hinge side. I did not have a chance to seal it up today but will in the morning.
    Might try looking around your door frame on the inside as someone shines a bright light around the frame on the outside in the dark.  Goose
TIDALWAVE View Drop Down
Direct Link To This Post Posted: 08 Oct 2012 at 8:52am
When I got my Pod I found that the factory had 'forgotten' to seal around the door frame.  With the door shut I could see sunlight shining through the gaps.  I had to use closed-cell foam and sealant to close up the gaps.
TIDALWAVE
g4royce View Drop Down
Direct Link To This Post Posted: 07 Oct 2012 at 11:42pm
All windows were latched and I had put the obligatory paper towel behind the latch part to catch any spray that might force itself in through the space between the panes.  It's also my litmus test for side-window leaks Tongue
We haven't done any of the door mods so there aren't any additional holes there to deal with that we know of.
ChaiPod
2009 RP152
2011 Hyundai Santa Fe 3.5L V6
Direct Link To This Post Posted: 07 Oct 2012 at 11:04pm
Are you sure you shut all of the windows, and latched them?  More than once I've almost forgotten to do that.
Direct Link To This Post Posted: 07 Oct 2012 at 10:46pm
We drove through some rain on the way home and when we opened the pod door we found water had somehow found its way just inside the door.  We had backed our pod up our driveway and the water pooled just forward of the door at the base of the lower bunk.
We're not sure if it's a frame seal leak or a door seal leak or something else entirely.  This was not the first time we drove through rain and we have driven through much heavier rain before.  However, this is the first time we drove through rain this year.
Does anyone have any suggestions on how to find the source of the leak?
ChaiPod
2009 RP152
