  New Posts New Posts RSS Feed: 1 # propane bottles
Topic Closed1 # propane bottles
Podster View Drop Down
Direct Link To This Post Topic: 1 # propane bottles
    Posted: 21 Nov 2014 at 6:22pm
Cliff & Raelynn
Ranger 4.0/178
Direct Link To This Post Posted: 21 Nov 2014 at 5:58pm
Well, it is a tight community around here! Wink
I just figured I would try some since I had them sitting around. It will be kinda fun to see if they hold the weight. Good thing I'm not 15 again or I'm sure I'd (or one of my delinquent friends) would figure out something to do with a leaking propane bottle!
Direct Link To This Post Posted: 21 Nov 2014 at 5:47pm
You may have the only batch on the planet that don't leak!
Direct Link To This Post Posted: 21 Nov 2014 at 5:22pm
OK, now you guys got me wundering 'bout this refill idea. So, I just ran out and grabbed one I refilled two days ago. Still same weight, but I'll check again in a few days.
Outbound View Drop Down
Direct Link To This Post Posted: 21 Nov 2014 at 4:48pm
Toss them.  The valves on them are so cheap, usually after just the first hookup they won't seal right again.  I used to have an adapter that allows you to refill from a 20 pound tank and every one I tried I had to keep hooked up to an appliance to keep it from leaking.
I've had exactly the same experience.  It didn't matter if they were brand name (e.g. Coleman, Bernzomatic) or off-brand generic, the valves on the 1-pound tanks would always leak.
Direct Link To This Post Posted: 21 Nov 2014 at 4:46pm
I most often use the little Worthington 1 Gallon tank and adapter hose for grill (Weber Q), single burner stove (Sportsman Cast Iron) and peace-of-mind pod backup. Can also be used for Mr. Heater Buddy heater.
Recently, I decided to mess around with the refill adapter thing and some one pounders I have sitting around. Besides the 1 gallon tank, I have a couple of 20 pounders anyway. The few (Coleman) refills I have done seemed to work just fine. I weighed the empty bottle and came within 1 ounce of full (net 1 pound) when refilling. Tested with soapy water and no leaks. I think I'll pick up one of those Coleman single burner stoves and try one out.
Not sure how much I'll use them, but I'll keep a few around (in the shed) when I don't want to use one of the larger tanks.
Direct Link To This Post Posted: 21 Nov 2014 at 2:45pm
I use a 5 pound bottle.
Direct Link To This Post Posted: 21 Nov 2014 at 2:39pm
We drop the tanks off at recycling.
Direct Link To This Post Posted: 21 Nov 2014 at 2:01pm
Yes, I have not seen, but have read that there are small tanks designed and rated for refilling.
Cliff & Raelynn
Ranger 4.0/178
john in idaho View Drop Down
Direct Link To This Post Posted: 21 Nov 2014 at 1:27pm
that is what I thought.  I saw at the RV dealers the other day, the cutest miniature propane tank, refillable just like the big 20 lb. It looked like it would hold a gallon, and with a hose with adapter, it looked like it would be even better than the little  one lb. ones.
