  New Posts New Posts RSS Feed: Hot Water Heater ByPass
Topic ClosedHot Water Heater ByPass
Direct Link To This Post Topic: Hot Water Heater ByPass
    Posted: 11 Jan 2016 at 12:00pm
Could have a one way on the "out" side of the WH..
CharlieM View Drop Down
Direct Link To This Post Posted: 11 Jan 2016 at 12:27pm
Still can dump into the WH if it's been emptied.
Direct Link To This Post Posted: 11 Jan 2016 at 1:54pm
If it bypasses the cold water fill side, then meets the T of the hot/exit side, and there is a one way between it and the tank, it will not fill.
Direct Link To This Post Posted: 11 Jan 2016 at 2:04pm
Yes, but I'm not aware of a check valve in that outlet line. And if it is there that inhibits draining of the HW pipes and HW heater from the hot low point drain. All said I think the three valve setup, or two either/or valves, is best. Actually two either/or valves might be better since you would get either hot water, cold water, or no water, but not luke warm water.
Direct Link To This Post Posted: 12 Jan 2016 at 9:31pm
At first I thought it must allow some antifreeze in, but it can't be much.  I used slightly less than a gallon in the pod, and slightly over a gallon in the Salem, which I expect since the plumbing system is a little bigger.  Last year I even tried to drain the WH again when I was done and didn't get anything out.
