ouR escaPOD mods |
Post Reply | Page <1 4041424344 58> |
Topic: ouR escaPOD mods Posted: 29 Apr 2018 at 4:13pm |
I installed an electric igniter similarly to what StephenH did, but with a few differences. I got nervous about putting holes in the burners to attach the electrodes, in case I had to abort the project. So, I made a little bracket to hold them and screwed it onto the burner support post that's just a thin piece of sheet metal. I also had problems getting the electrodes to fit into the space between the burner and stove top. For the longer electrode I shortened it and had to bend it to get it close enough to spark near the burner holes. For the shorter electrode, I had to slide the electrode up higher in its bracket so it would get close enough for a spark. They're pressed in pretty tightly, so it was a bit of a hassle to get it to move but I finally got a good alignment. I ran the wires out of the hole where the gas pipe enters and had plenty of wire to mount the spark generator on the face of the cabinet below the stove, similarly to what StephenH showed in his foto.
The fit between the stove top and the electrode is really tight and the hold down screws for the stove top are a little bit at an angle, but it lights quite nicely. I suspect I'll be replacing the spark generator button from time to time as they're not very sturdy.
Post Options Quote Reply Posted: 27 Apr 2018 at 11:15am |
Thanks!
Post Options Quote Reply Posted: 27 Apr 2018 at 11:04am |
The electrodes each had a metal bracket. For both, I drilled a hole in the bottom of the burner near the edge and used a screw to attach them. On the longer one, I had to slide the electrode on the bracket since more of the ceramic insulator stuck up above the bracket before attaching it to the burner. I also had to cut some of the electrode length on the longer electrode and bend them to make sure they gave a good spark.The picture shows all but how they are screwed into the bottom of the burners.
Post Options Quote Reply Posted: 27 Apr 2018 at 9:46am |
StephenH, how did you connect the igniters to the burners? Did the mounting hardware come with the HD kit? Thanks!
DavMar
Senior Member Joined: 04 Aug 2017 Location: Lexington, NC Online Status: Offline Posts: 592 |
Post Options Quote Reply Posted: 27 Apr 2018 at 9:23am |
Marwayne & StephenH,
Thanks so much for the information on this mod I really appreciate both of your replies and the photos. |
marwayne
Post Options Quote Reply Posted: 26 Apr 2018 at 10:18pm |
I thought of drilling a hole in the bottom of the pan, however if you ever have something boiling over it will leak into the cabinet below.
Post Options Quote Reply Posted: 26 Apr 2018 at 9:37pm |
Home Depot was the source of the kit I used. I opted for simplicity, so I drilled a hole in the bottom of the burner and used a screw to attach the electrodes directly to them. Since the screw fills the hole, there is no gas leakage to worry about.
marwayne
Post Options Quote Reply Posted: 26 Apr 2018 at 9:21pm |
Yes I made my own brackets, bought the igniter at Home Depot they are for a BBQ
DavMar
Post Options Quote Reply Posted: 26 Apr 2018 at 3:19pm |
Thanks for the great pic's marwayne. Did you fab the L bracket out of aluminum stock? What was your source for the igniter assembly?
marwayne
Post Options Quote Reply Posted: 26 Apr 2018 at 2:27pm |
