ouR escaPOD mods |
Post Reply | Page <1 3940414243 58> |
DavMar
Senior Member Joined: 04 Aug 2017 Location: Lexington, NC Online Status: Offline Posts: 592 |
Topic: ouR escaPOD mods Posted: 02 May 2018 at 5:03pm |
Stephen,
Please post a review on this WD anti-sway hitch after you used it for a couple weeks on your trip. Looks interesting. |
Post Options Quote Reply Posted: 02 May 2018 at 4:46pm |
The newest addition to our towing equipment is a Hensley Cub. This hitch normally sells for over $2500, but Hensley is having a special, offering a significant discount as they are introducing the Swift Arrow and Swift Cub models. These new models use chains and a snap-up bracket to set the weight distribution instead of the jacks to do the job.
I originally ordered the Swift Cub. I installed it and found that there were things about it that made it less than desirable for us. In addition to the chains and snap-up bracket and lever, it has two support rods that are used to hold the spring bars while the chains are disconnected, stabilizing the hitch so it can be set for easier hitching and unhitching. These are less expensive to manufacture but for someone with arthritis, dealing with the pins, bars, and chains is more of a problem. I ended up exchanging the Swift Lift Kit for the standard jacks. They are a lot simpler once set up as one only has to deal with the hex nut on each jack to adjust the spring bars. I did a short test drive with the chains/snap-up brackets, and then another with the jacks. There is no noticeable difference in performance. Both are a big improvement over the Equal-i-zer. There is no movement of the trailer and the hitch is virtually silent. I could not hear any hitch noise--no bumping, groaning, squeaking or popping. The real test will be when we take off next month on our cross-country trip. Is it worth it? If it makes my wife and me feel more secure while towing, it is. I also expect that because of the way it works, it will be better at keeping us stable in conditions which might be too much for a friction-based sway control system. I returned the cover. It did not fit to my satisfaction. I will make a cover. I have some ideas about how to do it. Since the hitch stays attached to the trailer except for the hitch bar, I locking it two ways. First is the hitch coupler lock. The second is to bring the chains up through the Over Center Latch (OCL) bars and locking them together with a heavy-duty padlock. While these are not foolproof, when coupled with the fact that not too many people have Hensley hitches, it is likely to baffle the opportunistic thieves. A couple of pictures and I have to run. We have to leave shortly. |
Post Options Quote Reply Posted: 30 Apr 2018 at 8:12am |
I wish I had found the one you got, geewizard, from Amazon. It's a better deal than the one from HD.
geewizard
Senior Member Joined: 16 Apr 2017 Location: Spokane Online Status: Offline Posts: 347 |
Post Options Quote Reply Posted: 30 Apr 2018 at 7:25am |
I just finished my install just as Fred did above but used this https://www.amazon.com/gp/product/B007VAXQF8/ref=oh_aui_detailpage_o05_s01?ie=UTF8&psc=1 Otherwise, I followed StephanH's method. Works great. |
Post Options Quote Reply Posted: 29 Apr 2018 at 10:14pm |
Thanks, you too.
Post Options Quote Reply Posted: 29 Apr 2018 at 9:44pm |
Sounds good. Have a safe and fun trip.
Post Options Quote Reply Posted: 29 Apr 2018 at 8:11pm |
We'll watch out for you. We'll be with two other couples, one in a Sunray 149 and one in a motorhome. And remember, our Pod is the one with no decals, like a little white cloud.
Post Options Quote Reply Posted: 29 Apr 2018 at 7:07pm |
We'll be leaving in a couple of weeks to go cross-country again to visit our daughters and grandchildren. We will be able to do a good test also. We both have AZ and UT in our plans. It would be quite a coincidence if we were to see each other out there.
Post Options Quote Reply Posted: 29 Apr 2018 at 6:45pm |
The $12 cheap kit at HD, that came with the piezoelectric pushbutton. I like the long electrodes that marwayne put in, but I couldn't find any that were cheap.
Now that it's in, it's all working well. We'll see how it does when we leave for AZ and UT next week for a couple weeks of dry camping.
Post Options Quote Reply Posted: 29 Apr 2018 at 5:56pm |
Fred, did you get the battery operated spark generator or the piezoelectric spark generator?
