 Post Reply Post Reply Page  <1 313233
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Topic: ouR escaPOD mods
    Posted: 18 Jan 2020 at 4:02pm
Originally posted by mjlrpod
I like the double sided chock you have. I like that much better than the 2 single chocks I use on each side of the tire. They look to be made of aluminum? It looks like the center connector is a turnbuckle, so you can adjust the size of the opening ? I will be ordering them soon.
The center part is a square with threaded sections on the ends in opposite directions, so it works like a turnbuckle. The end sections are some alloy. It is heavier than it would be if it were aluminum. The description says it has an anti-rust coating, so I think it is plated steel.
http://pilgrim-wanderings.blogspot.com
mjlrpod View Drop Down
Post Options Post Options   Quote mjlrpod Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 9:11am
Ok, Thanks Stephen. I'm going to order probably 2, on amazon. I see people saying you only need one, but i'm thinking 2 is better. Cost alot more to buy a new camper than one of these.
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 12:50pm
2 is for if you are on level ground. If not, then an Andersen Leveler or Beech Lane Leveler works well if you need to raise the low side 4" or less. I have the Andersen leveler because the Beech Lane Leveler did not exist when I purchased my A. L. My first one broke, but was replaced with what looks to be a stronger version under warranty. This type leveler, when the trailer is leveled, also acts as a chock. I also have the BAL leveler, but I think that the BAL leveler is more suited to the lighter RPods. The jack screw is a weak link. If not lubricated, it can gall and sieze or it can strip out and drop the load. Plus, the tilting tire platforms can't be good for the tires.
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 5:02pm
We have used the Anderson Leveler for a while now. I would not take it up to the 4" limit they advertise, but 3" is probably fine.
Olddawgsrule View Drop Down
Post Options Post Options   Quote Olddawgsrule Quote  Post ReplyReply Direct Link To This Post Posted: Today at 7:25am
I like the Beech Lake Leveler, it has the grip mat! I use a piece of my old hiking bed mat under my Anderson's.. LOL
2018 RPOD 182g 'Lily'
2017 Tacoma SR5
Life is good!
Spirit of Adventure WebSite
