List Your Mods:
 Post Reply Post Reply Page  <1 6667686970 77>
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Topic: List Your Mods:
    Posted: 02 Aug 2019 at 9:43am
Originally posted by lms1958
I looked at the Amazon link for the
Grill Igniter with Spark Plug Wire
and it says that it requires a AA battery.  Where is the part of the igniter that has the battery, and do you have to take the stove apart to replace the battery?
No, at least on the one we have. You unscrew the ring around the push button, and the battery is held in there.
Motor7 View Drop Down
Post Options Post Options   Quote Motor7 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2019 at 4:17pm
Originally posted by boater
Hi , Boater here , we just completed installing the Forest River supplied 4 inch Lippert Axle raise kit on our 2018 178 . Unit has 15 inch tires and Lipppert torsion axle .  Just love the lift kit results  ,, good clearance , and do not feel we need new step unit. ( have single step) . Of course had to have the sway control / hitch system we use re done to facilitate the raised height . Also I will add 4 inches of blocks/ pads under the 4 trailer stabilizer jacks just so they do not go down so far .  After the initial kit  cost from Forest River , the  install was $250. re do sway bars $65 . Plan ahead however to find a dealer or service company to install the lift kit . Many are not familiar and will not do it . Took 2 weeks to get the kit from Forest River and they were extremely helpful .
We not feel we are ready for National forest campgrounds , boondocking and any gully’s for surprises that come our way .
In my opinion, all of the Pods should come with risers....best mod so far for us has been #1 - risers, #2 Solar, #3 - 6" Queen mattress.
2016 R-Pod 176T
Frogpod2012 View Drop Down
Post Options Post Options   Quote Frogpod2012 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2019 at 12:03am
Xtra storage.
ANOTHER ADVENTURE
Carolyn View Drop Down
Post Options Post Options   Quote Carolyn Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2019 at 2:22pm
It has been a while, but what do you mean that you Installed the tracks "... with #4 screws OUTSIDE the slide slots …" Did you drill new holes?
Carolyn
Kahonu37 View Drop Down
Post Options Post Options   Quote Kahonu37 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2019 at 3:37pm
Boater
Since the installation of the riser kit, have you notice any differences in towing, gas mileage, or wind drag?
We are looking to also increase our clearance, just doing the research after watching a couple of videos.
Do the Hood Rivers use a riser or are they built in?
2018 179
2012 NISSAN XTERRA (retired 12/19)
2019 RAM 1500 WARLOCK (new)
A.R.E. V Series Topper
WDH Equalizer 600/6000
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2019 at 6:26pm
After owning our 177 for 8 years (as of 10/2018) we decided it was time to add the riser kit as it was getting bothersome to unbend the rear stabilizers on a somewhat regular basis.  Purchased the kit from FR, cost was $ 150 including shipping.  Instructions were straightforward and all I used was 2 good floor jacks and simple hand tools.  Total time was just under 1 hour to do the job.
That being said we have noticed no difference in towing or gas mileage when using either our '13 Explorer or '11 F-150, both vehicles averaged 12 mpg which includes city, highway and a lot of mountain driving in the Rockies.  Have not had any issues with either sway or wind drag; we use a simple Curt anti-sway bar, works well for us.
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2019 at 10:16am
Both, depending on model year. Early versions had a riser. Later versions they just clocked the torsion axle.
Post Options Post Options   Quote Kahonu37 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2019 at 2:20pm
What is your clearance from ground to frame? We have the East Coast edition, 2018 with 15” tires an the torsion bar appears to be “clocked”. I believe our frame clearance is 18”, but I will recheck tomorrow.
2018 179
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2019 at 5:16pm
Clearance from the ground to the bottom of our frame is 16". It is a west coast HRE built in 2016 (with a 2017 VIN).
tcj View Drop Down
Post Options Post Options   Quote tcj Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2019 at 6:44pm
West coast HRE 180, built in 2018 with 2019 VIN.  Factory installed axle risers.  I don't know how to tell if the torsion suspension is clocked to add height.  With trailer level, height to bottom of frame is 19.5 inches.
2018 R-pod 180 Hood River Edition
