  New Posts New Posts RSS Feed: 178 Bypass valves
Topic Closed178 Bypass valves
JET View Drop Down
Direct Link To This Post Topic: 178 Bypass valves
    Posted: 22 Jan 2017 at 9:01am
Originally posted by Podster
I have done both the blow out and the draw through the pickup valve method.
Owners that have to store off-site where the option with having an air compressor with a tank on site is not really an option, will find the pink stuff option favorable.
I actually find the blow out method more time consuming.
Here is a pick showing the bed setup to make it easy to get to whats under...
Cliff thanks for the photo.
Is the photo shown with mods you did or is that how the set-up came from the factory?
Do you own a 178?
JET View Drop Down
Direct Link To This Post Posted: 22 Jan 2017 at 8:55am
Cliff, thanks a million for the answers and the photo. Great help.
JET View Drop Down
Direct Link To This Post Posted: 22 Jan 2017 at 8:53am
1) Where exactly is the bypass pump and bypass valves on my 2017 178? Pump is behind the service panel below the sink. Valves are under the bed.
2) What is the purpose of the "in between" bypass valve on the hose between the hot and cold inlet bypass valve? When closed, prevents hot and cold water from mixing when the other two valves are open. When open allows water to flow while the others are closed to prevent flow into the water heater.
3)What is the purpose of the bypass pump, if any, other then to be able to pump antifreeze thru the system for winterization? Not really a pump, but an uptake valve. It allows RV anti-freeze to be sucked up into the plumbing system by inserting the pigtail hose connected to the same valve into the anti-freeze jug, opening the valve and turning on the water pump.
Here is a great video by my main man Travis "aka...MoosePOD" on how all of this works...
Cliff, thanks so much for the information. I really appreciate the reply. Do you own a 178? It sounds like a tremendous amount of trouble to open and close the shut the bypass valves.
I am going to get a hold of my selling dealer Monday. When we received our initial walk thru it was done by a mechanic that had prepped and serviced our R-Pod. He at that time told me that it was already winterized, but he did not find it necessary to use the pink anti-freeze, they blew the lines out with compressed air and that was it. I never asked him, nor did he mention the bypass valves and their status of being open or closed, that is why I was looking for them to know where they are at and to be able to know how to access them in the future when I do add antifreeze to the system. So all this information brings me to these questions.
1) When I winterize is simply blowing out the system with compressed air enough? Or do I want to make sure I always add pink anti-freeze to the system (I live in southern Oregon and we do get cold winters, in the 20's)?
2) If I do winterize using antifreeze how difficult is it to...
a. access the bypass valves under the bed (tips and info would be greatly appreciated)?
b. access the pump and utilize the hose for uptaking antifreeze from antifreeze container?
3) How difficult is it to utilize the access to the pump (post mentioned it is under the sink behind a service panel) to be able to add the pink anti-freeze?
4) When winterizing by blowing out the lines, in lieu of adding anti-freeze, would you still need to open and close the bypass valves for this operation ( I assume no, but hate to assume anything with my lack of experience and knowledge)?
I NOTICED THAT WHILE I WAS WRITING THE ABOVE NEW QUESTIONS THAT THERE HAS BEEN SOME REPLIES THAT ADDRESS SOME OF THE QUESTIONS. I WOULD APPRECIATE AS MUCH INPUT BY THOSE HOW OWN A 178 AND DEAL WITH THE SAME ISSUES. THANKS...JOHN
Podster View Drop Down
Direct Link To This Post Posted: 22 Jan 2017 at 8:39am
Cliff & Raelynn
Ranger 4.0/178
Bama Pod View Drop Down
Direct Link To This Post Posted: 22 Jan 2017 at 8:32am
In my 180 both the heater and pump are under the bed.  I winterized using anti-freeze once, but it was such a pain in the arse that this time I bought an air compressor, drained the water heater, blew out all the lines, poured some anti-freeze in drains, and called it a day.  MUCH easier.
Bama Pod
Huntsville, AL
2017 Ford F250
2017 Airstream 26U
Direct Link To This Post Posted: 22 Jan 2017 at 8:13am
Cliff & Raelynn
Ranger 4.0/178
Bugout View Drop Down
Direct Link To This Post Posted: 22 Jan 2017 at 7:46am
The bypass is under the bed.you have to remove the mattress and plywood the you can see the water heater and bypass valves.or there's a small cover plate in the storage compartment in the street side.but it vary hard to see that way. The pump is under the sink on the floor.
Jk Aiken South Carolina 2016 178 Toyota Tundra 2017 4.6
JET View Drop Down
Direct Link To This Post Posted: 21 Jan 2017 at 5:56pm
I just got my new 178 home and am trying to get up to speed on certain things. I am quite sure my particular questions should have been addressed many times previously but I have exhausted my searches without getting specific answers, so I am indulging the forum for the answers. I am somewhat confused pertaining to bypass valves and the bypass pump. At this juncture I know that 178 has them but I would like to really understand what they are for. And I have been trying to find where my bypass valves and pump are located on the 178. I am under the impression (let me know where I am not grasping things) that the bypass valves are basically there to enable me to keep water from going into the water heater... and I would want to do that when I am adding antifreeze for winterization. I understand that there are 3 bypass valves...hot, cold and one in a hose in between the two hot and cold. I understand which way the valves are positioned to be open and closed (handle with flow=open etc.). My new 178 has not been filled with water yet, and I don't intend to do so right away (still winter and not going anywhere with it soon), I am assuming the the bypass valves are closed and before I fill the pod with water...to insure I get the hot water tank filled....I need to look at my bypass valves and make sure they are open (and the in between valve is closed) before I fill with water and turn the hot water tank on. So my basic questions are...
