  New Posts New Posts RSS Feed: Cant get cable to work.
Topic ClosedCant get cable to work.
Monemkr2000 View Drop Down
Direct Link To This Post Topic: Cant get cable to work.
    Posted: 06 Oct 2019 at 5:26pm
So I'm trying to get the cable to work. Ive hooked up the cable line from the pedestal to the POD. But when I go to scan for channels it's not picking any up. Is there a switch some where (2019 190 ) that I'm missing to get it to switch from the antenna. I thought the TV did the switch but maybe not??
"We must always be aware that suddenly and unexpectedly we may find ourselves in a role where our performance has ultimate consequences."
Direct Link To This Post Posted: 06 Oct 2019 at 6:26pm
When you are trying, do you have the antenna booster turned on or off? For cable viewing, it should be turned off. I have not tried it since we don't have cable, but that is what I have read. You may need to check the source the television is using also and change from antenna to cable, then you may need to scan for channels, but I am not sure about that.
Also, one other thing to check: See if the cable connection on the post is an active connection. It may be there, but may not have an actual signal going through it.
Buckeye View Drop Down
Direct Link To This Post Posted: 09 Oct 2019 at 7:44am
Happened to me when I connected to the cable port on the Pod (the one on the left) from the origin. Then I connected it to the aux port (the one on the right) and it worked.
Craig-retired teacher of the blind
Carol-retired legal admin asst
Spot and Sam-the miscreant Shih-tzus
"Politically incorrect with no real changes expected...”
Former 2017 Rpod 180
F150 5.0 4x4
Direct Link To This Post Posted: 10 Oct 2019 at 8:34pm
My R-pod only has one port. It says Cable/Satellite. Unless Im missing one somewhere. Did find a workaround. Just run the cable thru the slide out. Works until we get home and figure out what's going on.
