Forum Home Forum Home > General Camping > Cook'n With Gas
  New Posts New Posts RSS Feed: Dutch Oven  Biscuits
Topic ClosedDutch Oven Biscuits
rpodcamper.com View Drop Down
Direct Link To This Post Topic: Dutch Oven Biscuits
    Posted: 30 Nov 2009 at 4:07pm
I simply take some Bisquick and mix it up with enough water to make a dough that I can spoon out in biscuit size amounts. (This will take a little practice.)  I usually put 16 or so biscuits in a 12 inch oven. This size oven is good for biscuits.  Each biscuit must be rolled in oil (that's what makes them brown), so add enough oil to your oven to very lightly coat each one as you add them to the oven. Don't worry about their being round. It won't matter. Just crowd them to use up your dough. Now we are ready to add heat. I'm usually in a hurry, so I start with 8 charcoals on the bottom and 12 or so on top. When the biscuits have raised and begin to look like biscuits, reduce the heat on the bottom by two charcoals and cook until the sides begin to pull away from the side of the oven. You will see, as they pull away, that they are also beginning to brown around the edges.  When this happens, remove the bottom heat and continue to cook on top until they are as brown and crusty on top as you like them to be . The biscuits will take about 30 minutes. They are very easy to do; always a big hit at your cookout.
